That is one important point about CIS (all variants) that make it a true winner.
CIS will ALWAYS get you home with a limp-home mode if something does fail. For KE-Jet systems, even the ECU has a limp-home mode in addition to the mechanical portions of the system.
You can't always say that about other non-CIS x-Jetronic injection systems. And yes, agreed, some of the componentry of the D-Jet system (not just the ECU) could be troublesome, unreliable, difficult to diagnose, and DIFFICULT TO FIND REPLACEMENT PARTS FOR.
K-Jet is easy to diagnose with relatively simple tools, and if you know what you are doing it's actually a very simple system. Parts continue to be readily available (i.e. injectors), and other parts like the fuel distributor are completely rebuildable either as a good DIY or by an expert. The parts themselves do tend to be reliable (fuel distributor, intake air plate) and don't require a lot of maintenance. K-Jetronic also self-adapts as parts wear.
Injectors' internal springs do eventually weaken and injectors will dribble, but they are readily available and easy to replace. And they are still relatively inexpensive -- perhaps $40-50 apiece. Compare that to a new M119 injector.
