  • ATTENTION
    Thank you,
    Management
FOR SALE FS: 1993 500E 199 Black/Black, 206kmi, $16k (Burlingame, CA)
600Eric
a.k.a. "CoalRollerEric"
ADMIN EDIT 1: For sale January 2016 on eBay, see post 11 for details.
ADMIN EDIT 2: For sale June 2017, thread title updated with current info. See post 13 for details.
ADMIN EDIT 3: Price reduced August 2017, thread title updated. See post 14 for details.
Some "Interesting" mods, but not what I am looking for. Brabus Monoblock IV's are definitely nice though.
VIN#: WDBEA36E8PB868008
http://www.ebay.com/itm/271386397784 <--Auction ended Feb-5, 2014. High bid $10k, reserve not met.
1993 Mercedes-Benz 500-Series 500e - Porsche built Super Sedan
Hi, selling my beloved 500e . a rare car that was handbuilt by Porsche . she runs fantastic with no issues whatsoever ! . a brand new transmission was installed together with a new torque converter and flex disc at 169k miles by AutoBahn Motors in Belmont .
a new wiring harness replaced at 179k by John's European shortly after the chain tensioner and power steering pump replaced . prior to these engine control module .ignition coil tie rod ends also where replaced . the car also received a big brake kit from a MB S55 which consist of a 8 piston front caliper and 4 piston rears with matching cross drilled rotors and stainless steel brake lines all around .
a Berg Werks first gear start module installed. RennTech full suspension kit with rear adjustable toe & camber together with a set of Koni fully adjustable shocks.she currently has a set of H&R springs all the way around ( i think they ride better than the renntech) .wheels are staggered Brabus with new Kumho tires 245s front and 275s rears with H&R 12mm aluminum wheel spacers . a brand new windshield was installed because the originals where too pitted and developed a small crack . As you can see , she is not perfect cosmetically as seen on the pix . more than a few stone chips below the headlight and spoiler and wear in the driver side seat bolster and headliner . Cd player is non functional but everything else works! including AC ! a few small scratches along the door pillars .I believe the hood have been painted at some point in time .
really hate to part with her but I am moving my family far far away and import taxes and duties are just ridiculous and very expensive ! I will also include the stock airbox replaced by a Renntech carbon fiber intake and Eisennman mufflers out back . also part of the sale is a brand new pair of euro headlights and the stock amber park/turn light lense . Have clean title and all maintenance and build receipts .
Will not be responsible for any shipping arrangements. Buyer must arrange all shipping requirements.
  • AutoCheck_WDBEA36E8PB868008.pdf
Re: FS: 93 500E 199 Black/Black, 201kmi, eBay (Dublin, CA)
Bummer the car spent 10 years in NJ before moving to warmer climates. Those 8-pot front calipers are potentially dangerous, my 92 had a similar kit installed and they used thinner discs because that's the only thing they could make fit, and the caliper pistons were almost coming out of the bores. Bad, bad juju. I can't tell for sure based on the photos in the eBay listing but it sure looks like this is the same setup. I don't like the wheel spacers either but that's just me. The included Euro lights are incorrect, they are standard lights, not 500E Euros.
On the bright side, the mods are reversible if desired, and overall the car isn't in bad shape. Wonder what the reserve is.
What I want to know is where is factory rocker panel? Without it the car has lost its lower flare and looks like crap. The driver's front door lower cladding is not on right where it meets the rocker panel...or the car was hit.
It seems that the majority of 036's that spend time in Jersey seem to always end up being Frankensteined one way or another...
Re: FS: 1993 500E 199 Black/Black, 201kmi, eBay (Dublin, CA)
Good catch, Steve. Someone went to a lot of trouble to fabricate the custom rocker panels... which lack jack holes, in case you ever need to use that spare tire.
The wide moulding is not seated properly on the driver side doors, front & rear. Not sure what's going on there. Could be an easy fix, or not.
:beerchug:
This car has no priors in my database.
Steve:
Perhaps I'm wrong but I believe the correct term is Guido'd, not Frankensteined, for any car based in NJ for more than 3 days.
Ron
Affirmative, carrying the Guido badge was, is and always will be "industry" standard...I just feel like I sense another level of butcherism from the dark side...
F.S. 1993 500E pearl black/black 204K Santa Ana CA
http://www.ebay.com/itm/272072570765 <-- Auction ended Dec-17, 2015. High bid $11,600. Reserve not met.
http://www.ebay.com/itm/272100153561 <-- Auction ends Jan-14, 2016. Reserve auction.
nice wheels rentech box and what is that side skirt never seen that before
1993 Mercedes-Benz 500e
Selling my beloved 500e. Migrated back to my country two years ago. Regretfully, I must sell her. She has been a joy to drive, but needs some TLC. Feel free to email me or my son for questions or inquiries. You can see the mods in the pics, all tastefully done to compliment, not overkill the car.
The car is located in Orange County, CA. Buyer must pickup car in OC.
On Dec-14-15 at 17:56:50 PST, seller added the following information:
As pictured I installed a Renntech carbon fiber airbox ( original is included in the sale ) suspension consist of H&R springs with Koni adjustable shocks , thicker Renntech sway bar upfront. Brakes were upgraded with AMG SL 55 8piston calipers front and 4 pot rears with C32 cross drilled rotors and stainless steel brake lines . She sits on staggered Brabus 18x9 and 18x8s with less than 2k miles on new Nitto tires . Exhaust gases exits through a stainless steel Eisenmann muffler . Transmission was rebuilt at 175k miles and the timing chain guides and wire harness was also replaced . Paint has a high gloss shine but with age also has a few scratches here and there . Windshield was also replaced 2 years ago because of rock chips and pitting . AC needs attention though and rear most headliner is sagging a bit . Car runs smooth and solid . Everything works including rear shade and sunroof . Included with the sale are , brand new euro headlamps ... Mercedes car cover and sun shade together with original MB carpet and rubber mats ! Have all receipts . Thanks for viewing .
Admin note: Photos in Dec-2015 listing are identical to the photos from the Jan-2014 listing.
Re: F.S. 1993 500E pearl black/black 204K Santa Ana CA
Side skirts are AMG or replicas, modified to fit the widebody.
:pc1:
Hi,
Yes, nothing fantastic all together... and I am not a fan of the side skirts, it spoils the look of the car I think.
Alex
While I agree with you to the extent that the side skirts don't quite match the cars bumpers', I still think something is lacking in the stock 500e side skirts. The 500e having flared fenders and different bumpers than standard w124's, MB should have more aggressively redesigned the side skirts (rockers).
Hi,
Alex
https://sfbay.craigslist.org/pen/cto/6162601082.html
1993 Mercedes 500E Black Pearl Brabus Upgraded Brakes 1st Gear Start - $21,500 (burlingame)
206kmi
Super nice 1993 Mercedes 500E for sale with 205k miles aka a Wolf in Sheeps clothing. Serviced at Autobahn Motors and through independent service. Delivered on 7/8/1993.
This is not your average 500E and purists will have to look the other way :) You are probably already aware that 500E prices have been recently climbing and will continue to as the cars become harder to find.
On first look you notice the custom 3 piece Brabus wheels nicely tucked away under the 500Es wide fenders.
This 500E's stance is very sleek and aggressive due to the custom side rocker panels and HR lowering springs with Koni adjustable shocks.
For additional stopping power massive SL55 brake calipers front and rear were installed. Renntech sway bar and Isenmen Exhaust for a deeper exhaust note. It has AMG steering wheel wrapped in Alcantara with matching shift knob.
Service records are ultra important when buying any 500E. This car has received the best treatment at Autobahn Motors authorized Mercedes dealer in Belmont. Service records are included with sale.
Major 500E issues are done- Wire harness replaced, New transmission from Mercedes dealer @ 169k mi ($7000), AC compressor ($1200), chain tensioners, Berg werks 1st gear start $900, new Kumho tires @198k $834, new battery, CPS sensor and more...
Email for more info. Clean title.
Just a little update on the car. I spotted it in Jacksonville FL today. It looks like it has 207,682 miles now. I took some pics I can post, but feel weird as I was taking them without anybody's permission, car was just sitting outside next to the body shop (no visible damage to the car)
Thanks for the update. If the car was parked in a more or less public place, then it's fair game to post photos.
Looks like it sold in summer 2018 and it's a new owner in FL...? Or, the PO relocated to FL?
