Thank you for the info, this is exactly what I was looking for. So it seems that ROW 500E would be more a sports car, when US/Japan is a luxury cruiser that takes off with the second gear by default?Adding to what Gerry said, it's North American and Japan cars that had reduced "performance/functional" equipment. The 124.036 had the oil cooler deleted AND did not receive the braking system upgrade as of approximately Mar-1993, for both USA and Japan. ROW, including Germany, had the oil cooler and enhanced brake system. So it's not really German-delivery cars you want, it's anywhere outside USA/Japan, if you want all the goodies.
Similar with 124.034, USA and Japan received 2.24 granny gears with FGS, ROW had 2.65 gears and SGS.
USA and Japan have low speed limits and MB didn't think it was worth the cost to provide stuff only used at high speeds. The 2.24 gears also allowed MB to skate around a gas guzzler tax on the .034, IIRC.
Sorry, did not see 034 mentioned.All 036's worldwide, all years, have 2.82 axle ratio and start in second gear.
It was the .034 that had different gearing/valvebody in USA/Japan vs ROW.
The option list you show above appear to be a normally-equipped German market car, not stripped-down. The last 6 digits of the VIN would indicate if it has the late/fancy braking system. Other than possibly having manual climate control and a fire extinguisher, the equipment looks nearly the same as USA-market as far as options.
No. E/S is Economy/Standard. It adjusts the shift RPM. Economy makes it upshift early, at low RPM.Sorry, did not see 034 mentioned.
My unit does have manual E/S switch next to the shifter, so S means start in first gear, right.
Yep, back in the 80's and early 90's. Mercedes Benz (in the UK at least) only provided central locking and power steering as standard. A friend of the family was a diplomat back in the 80's in London and bought a Mercedes Benz 190 in 1987. It had a 4 speed manual, crank windows and cloth interior. It could still do 100mph on the Marylebone Rd and did many times.Basically think of it that all E500Es imported into North America are going to be fairly maxed-out in terms of options. Japanese cars also had generally pretty strong option lists.
Non-North American cars will generally have fire extinguishers and warning triangles from the factory; North American cars NEVER had these from the factory.
I've actually seen "stripper" model 500Es per the data card info, with next to no options. These tended to be earlier in the production, but were always buyer-specified options (or lack thereof).
I believe in your first sentence you meant to type "second gear".All 500E and E500 shipped worldwide start in first gear. ALL markets.
The 400E and E420 have first-gear start. This is why the 400E420 (.034) valve bodies are in demand among some 500E owners as an "upgrade". You will find dozens of threads on the forum of these for sale over the years.
A few reference threads that discuss the first and second gear start & related characteristics:
No North American W124 model of any type was imported with an E/S switch. Later chassis (W210, W203, etc.) had them, but never the W124. "S" only controls the shift point, making it hang a little longer before upshifting. "E" uses earlier shifts for "economy."
That is about an average German-market data card. Not fully loaded up, not stripped. I would say about 80% outfitted as compared to what you would see for US-imported models.
What is the FIN of this car you bought?
IMHO swapping gears to 2.65 is the greatest mod you can do to a 034....and allow .034s to skate around getting 25mpg with 2500rpm at 75mph, yet ready to wake up at a moments notice...
The 90, 91, and 92 500SL dif bolts right in![]()
99% plug & play, for ASR models... the R129 ASR diff has sensor wires a few inches shorter. You may need to swap the sensors from the W124 diff, but otherwise yes, it bolts straight in.Zero modifications required? As in literally plug-and-play?
What a great color!I remember this cristall green dutch car....no options, not at all. Leather and tow hook added later. No el.roof, no el. steering column,no nothing.
This looks like a 94/95 model, yet it has a manual climate control (just like mine) and face lifted exterior. Was it re-dressed as a later car, or Euro cars were ahead of the US models?I hope i´m not too off topic here, but i found all pics of this car. 8900 Euro, back in 2012......
I bought a W124 300TDT in the 1980's in Germany.Yep, back in the 80's and early 90's. Mercedes Benz (in the UK at least) only provided central locking and power steering as standard. A friend of the family was a diplomat back in the 80's in London and bought a Mercedes Benz 190 in 1987. It had a 4 speed manual, crank windows and cloth interior. It could still do 100mph on the Marylebone Rd and did many times.
For a non-ASR diff, I don't know if the single sensor wire length is an issue. Still bolts in other than the sensor wire concern.
Either scenario requires an electronic speedometer conversion box behind the cluster, I use the YellowBox from Yellr.com.
They came both ways. One sensor is for no asr, two sensors for asr. The scrappers in Nor Cal sell them for $100 either way and they pull them from the donor car for you. Worth every penny.Dave, were there SL's from 90-92 without ASR?
As said- original dutch order, no options.The manual dual climate control was not offered for the US market. Your car must be an import?
The face lift happened at the same time for all countries.
drew
Sure.Dave, were there SL's from 90-92 without ASR?
Yup, as mentioned by Kegman and 036, the 129.066 had optional ASR. If shopping for a diff, you must get the VIN of the donor car, or better yet a photo of the actual differential BEFORE they ship it. Very easy to tell the difference based on the sensor location & quantity.Dave, were there SL's from 90-92 without ASR?
Yeah, lol I’m on the prowl for a clean 5L engineYup, as mentioned by Kegman and 036, the 129.066 had optional ASR. If shopping for a diff, you must get the VIN of the donor car, or better yet a photo of the actual differential BEFORE they ship it. Very easy to tell the difference based on the sensor location & quantity.
At this point you might consider springing for the 5.0L engine too and making a narrow-body 500E!!
I did mis-type, and will correct it. Thanks for flagging that.I believe in your first sentence you meant to type "second gear".
drew
