Headlamp Restoration
124500E
Hello,
since some people like to keep a few pairs of headlamp lenses in stock so that they got a spare, if something happens. People who are in need of new lenses don't get some.
So now i make a virtue of necessity and restoring my headlamp lenses. I started to tear down the headlamp assembly and get out the reflectors:
Together with these plastic frames i will send them to a company who can make a new layer the alumium coating.
The old coating comes of really easily. But the glue that holds the glass and the frame together ist really hard to remove. So as the glass itself. It got baked at 100°C for 30min
Now my next goal is to get the glass looking good again. After a round in the dishwasher they look way better then before but the sand blasting look needs to come of. I talk to an glass master in my town and he said that its possible to sand and polish glass. I will try this and keep you informed!
Greetings Jan :)
Often, a Dual action orbital polishing device and cutting creme work pretty well.
Use cerium oxide or carpro ceriglass polish with ceriglass pads on a rotary polisher and you can have a good clean glass. Although avoid touching inside of glass with your hand and avoid polishes on inside as well.
Hello, anybody got a suggestion for the correct glue? I'm thinking on windshield glue but i dont know its reaction to the plastic frame ...?
We use this
Very good product and even better than butyl
which is usually used on headlights but is basically windshield sealant but in different form.
With retro rubber you can easily do
2-3 sets.
Now how to use it
Watch this video
Or for full in depth details watch this one
Retro rubber and butyl works the same way but retrorubber is less tacky so wont dirty/stick to your hands or area inside engine bay etc. But since its harder than butyl so as an additional step, its better to heat the roll for a 2-3 minutes in oven before using it, as it helps in making it more flexible while putting inside headlight.
Hello,
i know butyl lines from sealing chassis parts where water intrudes the car.This stuff always stay flexible and don’t hard all the way.
Hello,
Yes as stated above. But it works well and was used widely through out the world until retrorubber was introduced. Thats hard compared to butyl and is not that tacky. It is my now go to product for resealing headlights and I only use butyl when I am out of retrorubber.
If you are sanding glass, I would be wearing gloves, and perhaps a mask or respirator. The last thing you want to be doing is touching fine particles of glass, let alone breathing them into your lungs.
