Accidentally snapped OEM cps during test fit of manual trans… ordered this HELLA cps from FCPeuro. Different style face on the sensor side, normal for aftermarket?
That Hella sensor is aftermarket, not OEM, but should work ok. Dunno how long it will last but at 1/3 the price of OE/OEM it's worth a try. Don't worry about the visual difference.
OEM is either Bosch or AB Elektronic, more details are in this thread.
Unfortunately the plug side is pretty tight on the EZL… basically have to force it on because the plastic diameter on the terminal of the plug is too small… UGH!
If the Bosch has a metal shell at the sensor end, apply anti-seize before installing into the bracket. Otherwise they can corrode in place causing a real nightmare the next time it has to come out.
The AB/K version has a plastic sensor end, but I believe those are NLA via aftermarket channels. Not sure what you get in the box for $175 from the dealer nowadays.
To update, the Bosch one from FCP is indeed the metal housing sensor...wah wah wahhhh. I'll be sure to grease it up well before install and will be on the hunt for another OEM version in future... or I'll repair the original. regardless, must move ONWARD!
