As some of you know I just picked up a 94 E500 with 160K miles, I got it in San Francisco and drove it home that night 500 miles to Del Mar. I was keeping a close eye and ear on it all the way home to make sure all was ok and it was, all went great.
Today I soaked the motor and under carriage with degreaser and and carefully pressure washed it all, I did this a few times.
She started right up and ran great again with no issues, but about in 10 minuets I look see the temp gauge at maybe 110, so I turned off the AC and cranked up the heater as I have always been told this helps cool the motor down. I kept the car moving at a good speed to keep cool air moving across the motor, but the temp slowly moving up until it hit 120. At this point I'm worried it's losing water or some other big issue, so I pull over turn it off and pop the hood but all looks ok. The over flow tank is 1/2 full, its hot but not boiling, so I let it cool down for about 30 mins until its reads 80. I then drive it home for another 10 mins and the temp reaches just over 90, at home I pop the hood and again all looks normal. The only odd thing I can find is that the washer tank and fender next to the over flow tank are both HOT I can't keep my hand on them, they feel much hotter than the over flow tank.
Any clues ? What do you think a bad thermostat ?
Thanks guys
Thanks guys
