I've had the car for 12 months, and only just noticed that the headlamp wash/wipe operates when you use the windscreen washer - whether or not the headlamps are on! I assume that normally the headlamp wash/wipe would work only when the headlamps are on?
This in itself is not a disaster - but more annoyingly, when the headlamp wash/wipe works when you use the windscreen wash without the headlamps on, they don't park properly. To get them to park in the "down" position, you have to turn the headlamps on, and then depress the column screen wash, after which they will park properly. (Hope that all made sense!).
Any simple answer, anyone!?
