before we start: The car was running fine despite degraded upper wire harness. in 2014 my wife passed and the car sat for the most part of 6 years. occasionally taking it to gas station or moving around shop. it started running rough and then the abs and asr lights came on and stayed on. so i then replaced the obvious upper harness that was degraded(no change in running performance), it then started to stall when warm and no chance of restart until it is left to cool completely,..then it starts fine and runs until warm again. had the codes read(which was a chore in NC,..no one except dealer had the ability, finally found one guy) I will post pictures of codes read. at this point I have replaced both fuel pumps, filter all 3 coolant temperature sensors, fuel pressure regulator, complete brake job with sensors, cleaned the abs sensors, cleaned the caps and rotors replaced spark plugs and wires, cleaned maf and inspected the throttle body wire harness(looks brand new-might have been previously replaced) and did the start up tests and it makes all the right noises and movements. battery is brand new agm fully charged. new crank sensor and new cam sensor. fuel pump relay used to click rapidly at idle, replaced relay(didnt do anything),..still clicked, but now rarely clicks,..but sometimes it comes back. I am wondering if its the computer but at this point sick of throwing parts at it. if anyone can help I would appreciate it. im in the boonies of NC and the closest MB place that still works on older models is in GA.
