Idle issue intermittent on lh 1995 129
Yorkabenz77
Active member
Recently acquired another 95 sl500 with low miles and good records.
Shortly after purchase, it developed a miss shortly after startup after sitting for a week....and after driving and getting up to temp, idle in gear gets bad. Really felt like a typical cap issue with moisture buildup.
After driving for a bit, the engine runs great. Even when it was idling poorly, acceleration was fine.
No fault codes found.
Plugs were iridiums.switched to f8dc4 and gapped.
Ruled out caps, rotors, rear cap covers, and leads.
Upper harness is updated but throttle body is original but shows no issue.
Maf was rebuilt but have ruled that out.
Took out EGR and appears to be moving freely.
If I drive it for a day, park overnight and drive it the next, car doesn't repeat issues. Only seems to be if it sits for multiple days. I will also drive to a destination while it's missing at idle, park.it for a bit and will then give no.issue for rest of day.
Again, it feels like a typical cap moisture symptom or a stuck EGR sucking in unmetered air.
Has anyone experienced this?
I have also noticed the rpm at idle sometimes will sit at 500 rpm and not increase after shifting to p/n. Again, no code...assuming it's a safety switch intermittent issue. It'll do this with a smoothed out idle as well.
Assuming it's not correlated.
Thanks!
This is a textbook case of moisture in the distributor caps after a cold start. Adding extra vent slots to the caps will almost always cure the issue. You also must eliminate oil leaks from the intake cam solenoids. Additionally, remove the rotor bracket and inspect the back side of the insulator. Make sure there isn't goop/liquid on the back side of the plastic (it isn't moisture, the liquid does never evaporates).
Swapping caps/rotors from another car doesn't help with diagnosis, the car will run perfectly with either set of caps/rotors. The issue usually only returns when the car is parked for days or weeks, then the cycle repeats.
Full details are in the thread linked below:
Welcome to the forum!
:welcome4:
:welcome4:
I've ruled that out completely with swapping dizzy caps, and rear cups from my other sl that's been a daily with no issues for years. Has beru caps. The ones on the new car were almost new Bosch which were placed in the old one with no issue. The rotors are also like new.
I guess in a way the rotors could have micro cracks in it but you'd think symptoms wouldn't just go away especially when hot...
No oil leaks
:welcome4:
It's really weird because the symptoms really do seem like it would be a moisture issue...
The intake cam solenoids are seeping oil a tad but internally behind the caps are bone dry and clean...
:welcome4:
Sorry, I misread....
I was assuming you were talking about oil leaks from the exhaust cam seal....
I wouldn't think the solenoids would cause it. They were seeping but it was pretty minimal...and the car has about 63k miles on it.
Damn....if that's it, I'm going to be mad,.lol
The tiny oil leak from the cam solenoids deposits engine oil at the lower edge of the cap, where the high voltage arcs may react with the oil... at least, that's my theory. This is the secondary issue though. Sounds like your cam seals are dry, which is good, those are a nuisance to replace if leaking.
The main problem is moisture. Try cutting the extra vent slots into a set of caps as shown in the thread above. I think there's a >95% probability that will cure your issue. This has worked for dozens of forum members with the identical symptoms you describe.
The beru caps...which seem to be made with different materials...have never given me issue even with sitting after heavy Florida rainstorms and humidity. This issue was happening in a more dry climate in the Midwest late summer/fall with more dry conditions. Shifting parts and making sure they were dry didnt make a difference and there was no oil within the area
One way to confirm 100% if it's secondary ignition is to view live data from the EZL while the problem is occurring. If certain cylinder voltages spike from ~35 to ~70 while the misfire occurs, it's absolutely secondary ignition. This will show you which specific cylinders to investigate. >90% of the time you'll find the affected cylinders are all on the same distributor cap, usually the passenger side. You'll need SDS with functioning HHT-Win for this, video below at 0:40.
I'd still cut the extra vent slots. It's free, easy, and you have nothing to lose.
:hornets:
Unfortunately, I only have a blink reader and nobody in the area seems to have a proper diagnostic system to get live data
Update: after going through and inspecting/swapping ignition components back and fourth from my other sl, I found the issue....
It was the first things I inspected and since the issue was getting gradually worse, it must've missed my eye originally...
The other rotor also has small cracks at the bottom ear where the bolt was. This car was bought at a benz dealer and ignition components looked brand new. These are genuine benz rotors and were already failing
I'd like to apologize for misleading the forum. I claimed earlier I swapped caps/rotors. I did not swap rotors. Only inspected them. The damage wasn't nearly as visible when I did so. The misfire got progressively worse in a short time though. This would have screwed with cyl 2 3 5 8. Hopefully didn't cause too much damage with fuel dilution although it was still intermittent and got better as it reached 80c.
Keep it simple, 😂
Thank you all for the help. This was a ride.
