ignition module
Does the 420 E ignition module work on a 400E? The number from the 420e is 015 545 60 32 and the 400e is 013 545 63 32
If you need 013 545 63 32, why not get 013 545 63 32? They are commonly available on eBay at reasonable prices.
The EPC specifies a unique part number for the 4.2L engines based on engine number or VIN. I haven't tried the exact combination you describe above and don't know if it will work or not.
:mushroom:
I do know that an early ‘92 400 EZL works perfectly OK in a ‘94 420, and vice versa…
I suspect all 420/400 EZL’s are interchangeable without noticeable consequence pro or con.
EPC notwithstanding.
