1992 400e, vin WDBEA34E0NB761762.
had an issue with intermittent stalling while driving, leaving me stranded at one point and had to have it towed home. Found corrosion at the connector for the fuel pump relay, fixed it and it ran great for a 20 min drive. Almost home and it died again.
Checked and I’m getting intermittent power (mostly not power) on the green/brown wire from the LH module- and only when it’s connected to the fuel pump relay. If I unplugged the relay in back probe, I don’t get any signal from the LH module. I have good battery power in on the large red wire, and I’m not sure if I’m supposed to be seeing a ground on the red/black common wire, but I’m def not.
I’m suspecting the LH module is failed since both the brown/green and the common red/black both come from that module. I’d like to find a replacement tonight but am not sure of the part number and the car is at home. Can anyone help with the correct p/n for the LH?
Please and thank you!
