WANTED Instrument Cluster Needed for 1993 500E
Dswood
E500E Newbie
New Member
Howdy I need an instrument cluster for the 500E W124
A bunch of the 6 cylinder are available but none for the V8
Please contact me by text 949-294-6990
Assuming you have a 500E... it will be easier to repair your existing cluster. Finding a replacement will not be easy, nor cheap.
An alternative is using a 400E cluster with a converter box to adjust for the different gearing & tire size.
:burnout:
:burnout:
Thank you Good idea We have tried to repair unsuccessfully so far 👍
The odometer stopped working and looks like gears are worn out/stripped
99.99% of the time, replacing the gears will fix this. There are 3 small gears that soften and fail. Full details are in this thread:
You can find replacement gears on online (ebay, etc)
