Does anyone know what kind of resistance the big spring-type dropping resistor behind the left headlight should indicate? I measured mine with a Sears digital volt meter tonight and it's showing .8 ohms. When the fans come on, the current and voltage as measured across the resistor is 4.2 volts and .27 amps. The voltage sounds right but maybe I'm not measuring the current correctly because it sounds really low. Do I measure from the bottom resistor terminal to the top resistor terminal or from the bottom terminal to ground? Or does it even matter? It seems that about every two years I find myself cleaning and repairing the wires and terminals to this resistor. It's amazing how much heat it generates. Do these resistors go out slowly or do they usually work until they completely fail? Thanks!
