A tiny big update on the yesterday and today"s doings on the EvoLtwin
Got some new parts ,and i have done some repairs and preventative maintenance as well..so here goes..hope you dont mind the amount of pictures
First of all...this box came in
And it contained this little box inside
Finally opened them up..and found this inside
And vooila
A nice sparkplug cover made in carbon,and the AMG logo on it.
Then i got myself a new left taillight..as the old one was cracked on the side,and the right one was mint
Comparing
Cleaned the new one
I had to remove both..to clean up the panels behind the taillight..even though the car is painted 6 months ago.
Fitted the new one
My only problem now..was that the two taillights are a tiny bit different in color..so luckily ..i went back to the guy i bought it from and asked if he by any chance had the right one too..and he did
..so that taillight is now on its way from the states
I also received some new stickers to put around the car..these are the technical stickers with tech info on them..and warnings
Super nice way of detailing your car
Then it was time to really do some repairing work
I have been wanting to fix the notorious lap timer display,and i received the new LCD display for the lap timer,and for the outside temp gauge in the cluster.
Loosen the two screws under the ashtray..i guess there are two screws missing on my car...as you can see on the wholes abit on the upper side of the ashtray
Take out the whole assembly,disconnect the wiring on the back of the clocks,and remove them
Carefully pry off the metal surrond..you have to take your time..and not rush it.Do more prying on the side where you can see there is a lip on the plastic mainbody of the clock..these are the ones that hold most of the plastic housing IN the metal surround.
Just a note...be carefull with these pins when putting it back together.you do not want to miss the female contact in the other part of the clock
Unscrew these two screws..
Do not loose the screws or the fiber washers
Carefully lift the print plate away from the main body
This is how it looks
for some reason i forgot to take a picture of the LCD screen itself,for the lap timer.
But this is the old one
Put everything back in the reverse order.My tip is to be very meticilous when doing this job..the lcd display also has to face a certain way,which is very nicely described in the paper sheet coming with the kit.
I also installed new bulbs in all clocks before putting it back in the car for testing
Time for testing..and VOILAAA! its alive
happy happy happy times
And now...i continue doing the outside temp gauge in the cluster.
Remove the cluster from the car,
Remove these two screws..and you can pull the clock unit out of the cluster..the wires are abit old and stiff..so i did not get to pull the whole clock out,so i just pulled it as far as i could.,There was enough room to do the work
OLD BLACK faulty LCD display
Unscrew the two small screws holding the outer portion of the clock..down towards the screen
This is the part you want to come off
AGAIN,,,be very careful when taking it apart..and observe every position of the different components in there..and put em back in the same place when mounting it back in there.
the old screen and sealer paper bit
Notice there is a TAB on the one side of the LCD screen ..and it has to fit on the same side as the "groove" in the plastic housing..
Pay attention to this ,i try to show you here in these three pics
Also pay attention to the rubber side supports
This is the "paper sealer thingy" ...also having a "tab" on the one side...
And the last bit..before you can fasten this part back to the rest of the temp gauge
And as a preventative maintenance...i replaced ALL bulbs in the cluster
Another part i decided to replace while i was at it,is the hall unit sender which i ordered as a part of my faulfinding session on the stalling issue.
Now was the time to just replace it ,even this was not faulty,,i wanted to put my new sender in there
And cluster tested...all lights..AND the outside temp is working once again
I also fixed the broken hinge on the dash compartment ,there was just missing a nut on the one side..which made the lid ,loose
In the same go,,i saw that the dash compartment lightning did not work..so i found a loose wire..and a broken bulb.Re attached the wire..and put a new bulb in there.Good stuff
Finally..i trial fitted my new sparkplug cover.The writing was in white..which i do not understand WHY they did it this way..but i tried it..and i did not like it..so i had abit of an internal discussion with myself ,on what color to go for...either silver or gold..so you know what color it just HAD to be
even though i may change it up abit at a later point
what to do now?hehe
This maybe
oh oh oh...i also fitted my brand new original headlights...though they are not bought as Mercedes,,they are brand new Hella lights(but they are actually super old,they haven been on a shelf in Germany since 1990).which is the same as my car was delivered with.
Final picture of today
thank you for looking..and i hope you liked the pics..and that they can be of any use..i hope.
cheers
