Have scoured the board, thought I had seen the info one but couldn't find it anymore. So apologies if I just missed it.
EDIT: Right after I posted this the "related threads" module on the bottom helps with my question somewhat (http://www.500eboard.com/forums/sho...or-Brabus-wheels&p=10250&viewfull=1#post10250). But now I'm curious, do other people have this 8mm of threadless gap in their hub?
I have a question on lug bolt length, specifically in the rears. In my hub, it looks like there is about 8mm before the threads start. How much length do I have in the rears before I will hit the ebrake spring assy? On the fronts I know I can go longer, but curious about that max depth as well.
I'm thinking of going with the following bolt length, would love feedback:
FRONTS
AMG Mono IIs 18x8 ET31
10mm Spacer
A 50mm length bolt would leave 20mm of thread for the hub, and less the first 8mm of no thread there is about 12mm of thread holding the wheel on.
REARS
AMG Mono IIs 18x9 ET35
15mm Spacer
A 50mm length bolt would leave 15mm of thread for the hub, and less the first 8mm of no thread there is about 7mm of thread holding the wheel on. Should I goto 55mm?
FRONTS
10mm Spacer
REARS
15mm Spacer
