On reading the FSM for rear crank radial seal replacement it advises to not remove the rear crank cover plate. Normally this is what I do on m104's etc. I remove the plate, clean off all old gasket material, pry out the old seal and press the new one home before re-fitting with new sealant.
So.….. should I pry out the old oil seal and tap a new one home without pulling the cover?
Note I do not have the special MB oil seal press tool for the rear of the crank. (I have the MB tool for front crank oil seal though)
