Hi everyone.
My 1992 400E developed a misfire it idle seemingly overnight. It runs fine otherwise once any sort of throttle is applied. The car had been sitting for a few days but nothing out of the ordinary. The temps did get a bit colder but I am in Florida so not a drastic drop or anything the vehicle has not experienced before. I had already replaced most of the ignition components in 2019 when I replaced the car but figured it couldn't hurt to refresh as the spark plugs are on a short interval anyway.
So i started with caps and rotors (OEM). No change.
Then performed a compression test, all good. 145-155psi in all cylinders.
Smoked it for vacuum leaks and nothing.
Replaced the spark plugs with OEM plugs from the dealer, same as last time. No change.
Replaced the ignition wires (one was open with movement and they were old beck-arnley wires that came with the car). I replaced then with the appropriate BERU wires. The ignition wires definitely were in need, they were reading high when tested and I thought that would be my culprit. NO change....
So now I am brainstorming as to where to go next.
I did a search but nothing quite the same as my symptoms that weren't solved with ignition components. As always, any suggestions are much appreciated!
