My best piece of advice for you -- with those rubber "donut" rings that mate the two halves of the intake manifold together. MAKE SURE that these are installed correctly and none of them are pinched. After you have installed the rings and put the two halves of the intake together .... take a small flashlight and inspect around each of the 8 rings with 360 degrees, carefully inspecting even the inside with the flashlight.
I had a small section of one of my rings pinched on my M117 and it made a HUGE vacuum leak which caused the engine to idle quite high (900-1000 RPM). To fix it I had to remove the intake and re-do it -- not my favorite job
See the photos on this post: http://500eboard.com/forums/showthread.php?564-560SEC-top-end-rebuild&p=2555&viewfull=1#post2555
