Hello all,
As of the past two weeks i have been chasing this issue on my daily driver 92’ 400E to no avail and would greatly appreciate some support. So far it seems nobody has been curse with this problem on this forum(hopefully)
Problem:
only under warm conditions my idle is unstable but not hunting, smell of unburnt fuel apparent it is running rich and until anything more than a tap of the throttle it stutters and nearly/does stall. Yet reads about ~600 from the gauge cluster. This happens Typically after about 10 mins or so, not necessarily when it hits 84C. It also has the same but worse effects of stutters and stalling when in gear, over about 1700 the running seems normal and smooth but in gear at roadspeed can bog under more than light throttle.
So far i have installed: New Coils, New Distributors, New CKP, New FPR, Newer CTS(from November), Spare EZL(ran the same) My wiring harness is rebuilt, and has been running since a year ago last week when i finished my engine rebuild.
I have unplugged the MAF, Unplugged FPR, unplugged EGR, do not hear any vacuum lines undone. Fuses in the module box are good, everything is seated. Connector for ETA vacuum set.
My timing is not hitting the marker is needs to be out additionally, about a few degrees to the driver fender when its having its issues.
Currently i am suspecting i will need a replacement ETA as mine is original, but i am suspecting maybe it is the vacuum lines i believe 8mm running under the driverside distributors as i read in another forum.
Additionally attempting to reset the ETA seems promising, albeit not sure if it will provide a difference. I am in college so saving money so i can eat is nice. The past year with this 034 has been very cheap as opposed to a lease on a newer car.
Here are some codes i reset I assume come from this issue, since have been reset and have not returned yet issue remains. Other additional codes are from past repairs I didn’t wipe(cam sensor)
I also have running data stream numbers if that could help. Currently waiting on confirmation for a rebuilt eta on ebay 000 141 78 25
Problem:
