You need a thermometer to measure vent temps. Can't say if anything is wrong without numbers. Under $10 will get you a digital unit, like this one for example.Thanks for reply, the air is not cold as you would expect to be, I can tell it’s a few F* lower than outside, and it’s changing from time to time, you can feel difference in temp out of vents, I think it’s not ok
also I’ve found online that e420/e500 takes 8 ounces of PAG 46 and 33,5 ounces of R134a for a complete system charge
I believe the machines only remove the refrigerant, and possibly some oil. You can't remove all the oil without a lot more work, as a good portion of the oil remains in the compressor, and to fully remove the oil you need to pull the compressor out of the car.my question would be: if you trying to completely drain and refill system does those machines with vacuum draining out all these Freon and oil, or it’s just checking if you have a leak somewhere?
Evacuating, pulling vacuum, and charging with the correct amount of R-134a would be a good place to start. However, if anyone added oil to the system when it may not have needed it, excess oil could cause some problems. Hopefully that's not an issue.I guess I have to go somewhere for a complete test, drain and refill process as I was looking through web all night long, and found out a lot about ac fill/refill/overfill. Now my guess that I’ve messed up with correct amount of gas and oil, and to make it work properly I’ll have to go to someone who qualified for ac jobs, pay few $$ and forget about these
Neither is important to change right away, but the oil pressure sensor is nice to update so you can trust the reading on the dash. It should be steady at a given RPM. Neither sensor connects to any computer module, both go only to the instrument cluster gauge and idiot light, respectively.Btw oil pressure sensor and oil level sensor is not leaking, but is it important to change them right away, like in my case it’s just jumping on idle between 1-2 otherwise looks good, or this sensor will play with ECM causing car to misunderstand? Or it’s just a gauge on cluster just for me?
