If you've followed all the steps in the FSM (below) you may just need to use more force when sliding the panel upward. Also see if there are some YouTube videos showing this. The top edge tends to be pretty tight, but the panel generally will move upward enough so you can pull the top edge separately once there's room to get your fingers in there.
