Hi ,
Long time trying to start this M119 engine.
Afterwards troubleshooting all the ignition usual suspects, it was time to check Camshaft conditions and their timing.
Definitely by looking at the pictures attached, this engine was a neglected one.
Checking the Camshaft area, it looks dry, no oil around.
All the Plastic Chain guides are broken.
After turning Crankshaft until 45° , the right Camshafts sprockets are out of time by one position.
At the left side , the upper camshaft sprocket is out of time by one position, the Lower one is out by two positions.
Another odd situation , it was very hard to manually turn the Crankshaft with sparkplugs removed.
Please share your opinion ,
Do it is worthy continue to work this engine ?
