Good news is I was able to get a flat bed tow truck and my 94 E500 is currently at a local indie shop that was recommended to me.
After work last evening I started the engine as normal, fast cranking, but the interior light would not go out and the fasten seat belt light up on roof near interior light would not stop flashing even though my seat belt was latched.
I have seen this before and it was solved (couple months ago) by turning car off, waiting 5 seconds and restarting. So, I tried this again...
Dooooooooooooooooh...
Next thing I observed is engine would not start, not crank, but battery is strong. When turning ignition to start you can hear a click under hood near the abs unit, and I checked the fuses under hood with no visible failures. Also observed that the central lock (vacuum system) no longer works. I have never experienced this.
Can the collective wisdom offer the most likely causes? I know this is a guess, I am interested in the major systems that impact starter (neutral safety switch, solenoid/relay for starter motor, etc?). Is there something like this which may be on the same circuit for central locking?
Is this a typical failure mode for the ignition switch?
thanks all!!
Tomer
94 E500 ~ 97K on the clock.
thanks all!!
Tomer
