Hi All
Firstly, I hope everyone is ok, and doing as good as they can be.
On my 94 E500, the ac compressor was replaced with a new unit, everything was working fine, then I started getting a squeaking from the centre vent area for a week or two - I am presuming this was from the blower motor. Then suddenly air flow stopped when ac controls were engaged. No air flow for any setting (I have the auto climate control only). When I press the various buttons for air direction I hear something, I suspect this is the direction venting, moving but no air flow.
From reading I am suspecting the blower motor has gone bad - seems this squeaking is an early warning sign it’s about to go bad.
i need some advice on replacement - I am thinking to do the job myself. The problem is that in UAE, no parts are available locally either new or used; everything will have to be imported. So I need to make sure I order all the bits I will likely require.
does anyone have a parts list or can please point me in the direction where I can compile such so I have everything to hand prior to starting?
also, the original part is crazy expensive from what I have found where as UDO is cheap but questionable quality - is there a recommendation on a manufacturer to try and go with for this part?
before I order the parts, are there any checks I should do to check it is not something else other than the blower motor?
