I've got 4 questions about font struts
1. FSM 32-100. On one page it states that self-locking nut and washer that go onto the strut's road should be torqued to 80Nm. On another page (same document), it states to tighten to 60Nm (see picture). Which is it, or am I reading it wrong?
2. What is the retaining strap (see pic) for? Both of my front struts are missing them. They were replaced as soon as I got the acquired the car with Sachs 115-070 units, 5 years ago..
3. The above FSM states that an alignment must be performed after struts are replaced. I'm thinking of making sure that the 5 year old struts, that were put in by hole-in-a-wall indy shop are torqued to the steering knuckle and control arms to spec. If I loosen those bolts just enough to then properly re-torque them with a torque wrench, might this mess with my alignment? I just want to make sure...
4. 500E's MB branded strut has an "internal spring", which, from reading this forum, I know that aftermarket Sachs unit is missing. Is this unique to 500E only? Does 400E have a same/similar "internal spring", or, in 400E's case, it's irrelevant whether one goes with factory part or an aftermarket Sachs part?
Thanks!
Thanks!
