Where can I get aftermarket rear Windshild?
Gasket.. it's a pitaIs the rear glass bonded in or does it have a gasket?
...and goo too....but the gaskets suck and that's what I remember most...that and getting the trim out/off w/o bending it.Gasket.. it's a pita
Sent from my XT1585 using Tapatalk
Yes and yes...lighter too JIC weight reduction gets you excitedIs the pedestrian glass thinner?
Will it fit the same?
No, that is the difference... standard glass has fewer, thicker, more obvious defrost wires.Does it also include the defrost/deice strips as in the 500E?
AFAIK, the two types are completely interchangeable. I really, really like the fancy 036 glass and personally wouldn't use standard rear glass in an E500E. I'd actually like to upgrade my ' 87 300D project car to the fancy glass, someday, if it's still available for less than a kidney.Thanks GSXR! Are the connections to the deicer/defogger interchangeable between the two styles?
My 1992 only has one thin strand that operates. All the others have delaminated.
Dumb question: Is the outer edge of the fancy compound glass sealed, or open? If not sealed, perhaps running a bead of sealant around the edge of new compound glass might prevent or at least slow down the delamination issue in hot, high-humidity environments?
You guys are scaring me. Mine has a slight delam... something people will tell me not to worry about. And now I’ll be trying to convince those same people to do a hard job, in the FL heat and humidity. I’ve done it before, and often, tell them to do anyway what they tell me not to worry about. But I like to use that card sparingly. Ugh...
