FOR SALE Refurbished headlights for 500E/E500 (without lenses)
Oh excellent! Have you ever done a side-by-side comparison of light output between the re-plated/re-coated ones vs an original set? Are the both as bright and as clear in terms of light pattern/cutoff?
You mean to compare mine I offer with brand new headlights or used ones? I never though of it because at the moment I don't have enough room in the garage, everything is filled with headlights and parts for them. I can do comparison with used ones but each pair is different, some are extremely worn, others are not that bad. Each pair (I do many other headlights as well) I offer here or at any other place is tested before I put them for sale. The proper beam pattern is tested and verified because even slight misplacement of the bulb will disturb the beam pattern and it's easier to fix them on the moment than giving instructions to somebody 10 000km away from me :)
Great! One final check just in case - this Sept 29 set is optically great, and the inner light is the 500E aux high beam rather than the standard fog? If so I just may have to take these (and try to find 500E lenses).
@gtgoff, @simeon40 is an honest and standup guy. He is good for his word!
For what it is worth, you can find a set of lenses here for an, ahem, market correct 🤯, price.
-your neighbor, jlaa.
Hahaha yeahhhh, that’s 20% of the value of the car I might be buying 😂
Yes, the inner lights is aux high beam. Those in my post have two visible flaws which I showed. At the moment I don't have any other and I can't find any other in good/intact.
Take these lights, remove the cap over the fog lights, attach 036 lenses and call it good. The only thing missing will be the venting tubes which might cause fogging up once in a while and some corrosion in the long run. I have this setup since 2018 and it's been working perfectly with no corrosion so far. Note though that I purchased new Automotive Lighting pedestrian headlights back then instead of used headlights
Simon, just curious.
What would your price be for the bi led projectors above all in?
Thanks. Mike
The price varies by a lot of factors which are all optional for the client. The bare minimum with used reflectors (no shiny) and regular lenses without outer sanding and polishing, only internal one with NHK bi-led 3.0 inch projectors will be something around 700 USD.
Bi-Led cornering projectors can be installed as well. Check here mine on my car:
Simon,
That’s an incredible video.
What’s included for the complete package?
I’m driving the car not collecting it at this time. Theses light look awesome!
Appreciate your thoughts,
mike
Restored reflectors including the low beams one will be 220 EUR (232USD)
Sanded and polished glass lenses outside to remove 99% of the stone chips so they can look as good as new - 200 EUR (211USD)
Chromed frames - 180 EUR (190USD)
Cornering Bi-Led projectors will be around 450 USD to adjust and install but I'll need to make one pair to be sure. Everything should be plug and play but we'll need to discuss some other things like what's your headlight pin, if I have any available and few other minor things.
Another pair available for sale.
Will these fit pre-lift front end 036? If anyone has a pair of original Us spec w124 500e headlights for sale please dm.
Currently have standards oem from donor 300e
For the moment postal services have stopped sending packages to the USA so I won't be able to send any headlights to clients in the States
Should be sorted in a couple of days. The couriers are awaiting the new rules to come into force from tomorrow and will likely levy a small handling fee on top.
Hi
I send you a email a while ago, if it’s possible for me to ship my headlights ( without lenses), to you for refurbishing?
I didn’t get a reply, so I thought it might have landed in your spam…
Best regards
Niklas
Recently I don't visit this forum often so I would advise you to contact me on Viber/Whatsapp for quicker response.
Hi
Best regards
Niklas
Hi, Niklas. I have one pair available at the moment.
No, I don't have any available for sale. Also the pair from my previous post is available for sale. The price is the same as usual - 450 euros and if the buyer is from USA he'll receive them with the factory wiring adapter.
Simeon.
I have a pair of prefacelift headlights and lenses I’d like to trade for Euro headlights.
Any ideas?
Thanks. Mike
Will pre facelift lenses fit on the euro headlights or is it all or nothing?
Pre-facelift Euro lenses and facelift Euro lenses are fully interchangeable, as are facelift USA lenses. All of these will swap around between Euro housings and facelift USA housings. All of these lenses are a large single piece of glass and all look similar unless you know how to tell the difference between them.
Pre-facelift USA headlights are COMPLETELY different and NOTHING interchanges. Even the bulbs are different. These have a plastic lens over the inboard bulb and a large square hole for the separate square glass headlight globe. They look notthing at all like Euro lighs/lenses.
:run:
Got it.
Euro lenses pretty rare to find so mighty expensive I imagine?
Got it.
Euro E500E lenses are rare and mighty expensive. Several thousand dollars for NOS if you can find them.
Be careful, some lights & lenses are LHT (left-hand traffic) for UK/Japan, these are slightly easier to find and also less expensive. If you find a "too good to be true" deal, there's a strong chance the items are LHT.
:124:
