Hi all,
I am a newby to this forum and wanted to get your inputs on should I repair or sell my 1995 E420 SE. The repair would be the head gaskets(at a minimum), as there is a loss of coolant, drop in pressure reading, water mixture in the oil, vapor in the exhaust telltale signs. If so, what would you estimate that to cost?
I have owned the car since 2004 and had the major repairs done-harness, AC, PS, Water Pump, transmission rebuild, flex disc/drive shaft/throttle body, as well as usual maintenance. It has 160k on the odometer.
Clean interior/exterior/no accident/CA car/no rust/well maintained.
If I sell it, what do you all think it is worth?
Thanks,
Peter
Thanks,
Peter
