Squeek from engine at shut down
G Man
I've been noticing that when I shut off the car, there is a very quick, audible squeek coming from the engine bay. It sounds like a belt squeel, but I haven't been able to chase it down. There is no belt squeel while driving. Any recommendations?
My guess is a loose (or possibly worn) serpentine belt. How old is the belt? And how old is the tensioner? Your 1992 model has a manual tensioner, which is a PITA. Shame you can't easily convert to the automatic tensioner (gotta swap the timing cover, the early version lacks one of the required mounting bosses).
:choochoo:
I agree, sounds like it's time for a new belt. And hopefully NOT the tensioner!
My car just started the same noise -- time to check and adjust the belt.
I recall a discussion about upgrading to the auto tensioner. Where exactly is the missing boss?
The missing boss is on the timing cover itself. If you have a 1992 model, it probably does not have the boss. The 1993-94 model does. You can't install the later automatic tensioner unless the cover has this boss... photos are somewhere on the 500Ecstasy site, I don't have any on my website, yet.
:thumbsdown:
Turns out that my tensioner was on the path to total failure. It was a bit loose, so I tightened it, started the car, and it started squeeling all the time. The belt was so loose that I could remove it without tools.
The new part is on the way from AutohausAZ, along with a new adjuster and belt. Until then, driving will not be very much fun!
All fixed now. One thing I noticed with the new parts is that the tensioner pulley is swinging just a bit as the belt turns. The old one did not move at all. I suspect that the rubber got hard because of heat, and then separated from the inner bushing when put under tension.
