Hi all,
My 500E developped a strange clunk in the steering that is hard to diagnose as for now:
When driving at slow speeds and turning right there is a clunk at around 120° steering angle, and then again around 90° when steering back towards center.
It can be felt in the steering wheel, and even slightly pedals, so it's no light clunk anymore. When steering in slow motion at low speeds you can really expect it at a certain angle...
Strange thing is that when stationary and turning left-right... nothing!
Only when in motion. When driving straight ahead also no clunk or other noises when driving over bumps, potholes, ...
Have got it on my lift now, and nothing really to see:
- shock absorbers with topmounts are OEM MB new since 3000km, no leaks, all mounting screws are double checked and tight
- wheel itself turns smooth (and are tight), no bearing noises to be heard. Bearing play is set OK.
- steering arms have no play (also with pliers squeeze test), draglink had some vertical play so replaced with Lemforder (made no change)
- steering box has virtually no play in the straight ahead position. Ofcourse quite a bit when wheels are turned (but that seems normal with these boxes/benz era)
- steering column u-joint at box is tight, checked inbus-bolts. The 3 mounting screws of the box also tight.
- LCA bushes are also new since 3000km.
- Stabi bar has recent new OEM bushes .
- Steering damper is new, but removed it and no change.
- LCA balljoints were done 10.000km ago, MB dealer ordered OEM TRW's (with the black booth, I presume MB quality)
- No broken spring...
Fact that it only happens in motion, and only when turning right at an angle makes me think towards LCA balljoint, but no play to be felt... so I'm a bit baffled.... anyone with experience on their 500? Would be amazed it's in the steering box, but let's hope not.
Wheelbearing? Would be strange that it clunks when steering right with on other noises...
Thanks for the input!
I have had many. good luck.
