W210 E55 driver door latch
Glasgo_Chris
I bought a W210 e55, the driver door latch is broken. The cable and everything is fine after pulling door panel and inspecting, however the handle has no spring/resistence and does not go back into place when you pull it. Anyone know a good place to source a used driver door latch for e55? Thank you! 🙏🏻
Chris
You may need to figure out exactly what component is broken. Might be the complete lock/latch assembly (#5 in diagram below)...? If so, just get a new one for ~$120 from discount dealers. It's a fun item to replace.
can you post a link to where I can get a whole new latch assembly for $120? Much cheaper than Mercedes quoted me, thanks!
Driver door latch / lock assembly is 202-720-35-35... $162 MSRP. Your dealer may have quoted over MSRP, because they can. Take your pick of online discount dealers below. Naperville (MBOEMparts) offers free shipping with code 500EPROMO, but their checkout is broken and you have to call after placing the order to ask for the free ship deal.
Thank you sir! On a scale of 1-10 how difficult is the install? Sounds bad from you and poster above comment! Haha
It's been 5+ years since I did this, but from memory, it was somewhere around 5-7 difficulty on a 10 scale. I forget the reason why, but I think it's due to limited access, and that the assembly does not want to fit past the window regulator, or something along those lines. Plan on several hours DIY labor?
:sawzall:
