It's Free shipping. The guys in the mbworld W220 AMG forum have been rebuilding them for years. And they talk about them like you do the second one. The rusted one was, well, rusted.
You may or may not have these (attached materials). Sagging after a few days may or may not be normal operation, depending upon whether you believe MB. I'm torn over all of this. I think I replaced one valve block prematurely, following MB published advice, and the other (still original, 15 years on) is just fine according to that same advice. But the symptoms are crazy. Sometimes it sags after 2 days; sometimes it doesn't sag for two weeks; sometimes it doesn't sag for two months. Which makes me loathe to condemn a $1300 part (dealer wholesale). There are so many places where a rubber seal can let nitrogen pass (spheres, struts, connections, the rubber itself), that swapping the block seems irrationally in the favor of MB.
Last summer, I figured it was time to swap out all the spheres on the S55 along with the ABC fluid and filter service. So I did. The first 2 months of cold weather, it would sag after a week, but I noticed the fluid also showed low. So I topped off over the winter until now, I haven't driven it in 2 weeks and no sagging. So who knows. I think after a while, these systems are heavily dependent upon (1) new fluid and filter; (2) temperature; (3) barometric pressure, and all the other things that effect the elasticity and porosity of rubber. Short of re-doing the whole thing (new lines, dampers, seals, blocks, sensors and struts), I don't go chasing trouble. When it sags overnight every night with all new fluid and spheres, or when there's fluid apparent on hardware or the floor, then it's a problem. Until then it's not.
TSB here (
http://ww2.justanswer.com/uploads/HighwayRepair/2010-10-05_044036_ACE_-_12.pdf).. for how to diagnose a failing valve block. Note “Condition 2”. And I'm sure you're well versed on the ABC system by now, but the "Treatise" is worth saving.
