Hi All,
I have been chasing down an issue on one of my 500E with water trickling down into drivers footwell when heavy rain.
So I have now removed enough trim and items to be able to see that water is building up in the HVAC bowl if a lot of water is poured down there.
So a small constant stream of water is managed fine. Once I incrrease flow and the water starts to build up, the water is passing into the cabin.
This gasket (215) is totally wet.
Now my question is... im sure water should drain before it gets that high up in the bowl (drains appear clear) as a foam gasket will never hold water back anyway.
What am i missing!!?
