I'm hoping to get advice here about storing a car for the winter. I'm at the point now where my 500E stays in the garage when the snow flies; however, it still needs to be accessible on the rare occasion that I might need it in a pinch. So I suppose I'm asking two questions here:
1) What precautions should be taken when the car will see very limited use for several months at a time? For example, is it safe to add Sta-Bil to the tank? How often should I start it up and for how long should I let it run? Should I invest in a trickle charger?
2) What are the accepted methods for putting a car away for storage when it will be out of commission for several months without the chance of needing it?
I know when I was a kid my dad had an old MGB which he stored for the winters. I recall that he used to pull the plugs and squirt a little oil in the top of each cylinder, then replace the plugs loosely for the storage period. He would pull the battery and bring it inside to the heated basement where it sat on a trickle charger. The car was up on jack stands while stored (what's the common wisdom of this vs. keeping the suspension under load?)
Anything else related to cold-weather storage would be welcome, including tips and procedures for putting it back into service in the Spring!
