After careful consideration and due to multiple reasons (mostly money), I have decided to tend to my wood personally.
I had some screwdriver damage and age related cracking on the center console pieces.
Step one and two are done:
- sanding down and stripping the original coating (as much and as thin as possible) was not easy. Material MB used is extremely durable and does not dissolve. I tried to not run through the veneer with sandpaper but ended up with couple of little nicks that I had to touch up.
- applying epoxy new coating, at the local woodwork store, I picked the most robust epoxy coating I could find.
So far it set nicely, with no splits of fisheyes.
I am sure there will be constructive criticism and I am open to it, pics are attached.
P.S. Step three will be sanding off imperfections (another layer if needed) and buffing.
