Sincerely, 500Eboard Management
DISCLAIMER 500Eboard, including its owner, administrators and moderators do not endorse, approve or support any claims provided by sellers as to vehicle condition, history, title status or mechanical operation.
You realize the 19" are generally 2-piece, correct @TimL. Tough wheel to find in those offsets. I considered them for the S but they were near unobtainium then.
Hi Marcus, they are plentiful over in Germany with the S Class offset of 44. Problem is, the offset I’m looking for is for the E class and SL and they are more difficult to come by it seems
Tim, I believe you want these for originality /authenticity, so this may not matter... but those wheels might be quite heavy. The 18" version in the same widths are about 33 lbs each.
Edit: I believe these are intended for another MB build, not Tim's 500E...
@TimL,
Tim, IMOP you should stick with 18” wheels. 19s degrade the ride quality quite a bit. If it’s for show only go for the 19s but if your going to be your everyday drivers stick with 18s.
Just made an account to respond to this thread. Since my summer wheels just came off which i believe are the right P/N you are looking for, we might be able to work something out maybe. Just need to have them balanced and checked.
Came from an 03 e500. And since im looking for another set of wheels for next year im willing to let them go.
Ill be in the garage later and can check if they indeed are the ones you need.
Great! @MadisV If they are the right PN then please post some pictures of each of the wheels so I can understand their condition (front side and back side of each wheel, including P/Ns)
