Hello guys,
This is really something. I replaced rotors, the flexible brake lines, rebuilt the calipers. Nice, Porterfield pads on Zimmerman rotors. I went to bleed the right front and no brake fluid at bleeder even under 15 psi. From the Motive pressure unit. I removed the new Deerfield brake line, it's dry. I drove the car and all is well, except no right front brake.
ABS hydraulic unit?
Is there a check valve or blocking solenoid?
Has anyone ran into this problem? The car is parked again.
Any ideas would be appreciated.
David
ABS hydraulic unit?
David
stops great.
