Hey guys, following up on those two cluttered topics, http://www.500eboard.com/forums/showthread.php?t=1857 and http://www.500eboard.com/forums/showthread.php?t=3720, i'd like to start a new topic, specifically about fitting these 722.6xx 5 Speed gearboxes into our beloved W124 E500Es. I think this will be my next bigger project for my 500E the next 1-2 years.
To summarize whats needed:
- Gearbox 722.625 from E420/E50 AMG W210 (W5A580). Some Say also the ones from the W/C 140 and R129 do work - lets discuss this here.
- Aftermarket Standalone controller. Currently there are only two that shine out: The Ole Fejer unit, which was specifically made to fit the 722.6 and the more universal PCS TCM-2000 with a 722.6xx harness.
- Some fiddling with cables, electronics, ATF cooling lines, etc.
- Shiftpanel/Shifter-console from late W202 or R171 Series.
I've found this Video on youtube which shows the pros and cons of both units for the 722.6xx use in a W123 chassis: https://www.youtube.com/watch?v=XKrw--4Su1M
So i want to get this done, maybe next year after the meet in June or lets see what and when it happens. These gearboxxes are like 150€ of German Ebay. Sure enough a slight overhaul would be needed before putting them into the car. Ole and others recommend to get the clearance at the clutch packs as tight as possible and do a little mod to the valve-body.
I will also try to convice Ole Fejer to join our Forums and help us out. Maybe if there is enough interest, we could get some advantages, like adjustments for the 500E, 6L, 6.xL or SC cars. Or a group buy is also possible.
According to Russell (WhippleM104), the stock main shaft will fit these W210 Gearboxes despite them beeing 1/4 inch (6.4mm) longer than our 722.3xx boxxes.
Also i want the shift indicator like in the Ole Fejer unit, but much smaller to fit them in the stock IC and in amber color. Maybe we can look together for a small digital number unit.
There are still things to discuss here, Inputs that our LH unit in the 500E or the car strongly needs:
- Gear lever position,
- Overload-switch.
- Speed signal for the speedometer. I saw the Ole Jefer unit has outputs for speed that can even be adjusted and directly fires up a E500E/E420 speedo.
- Starter-Lockout switch too.
- How does kickdown switch work? I know that my CL C215 with the later 722.6xx box has full electrical pedal and "kickdown" is just more than 100% Throttleposition.
- Will S/W Switch work like expected?
- Can something solve the 3/4 upshift flare that both standalone TCUs deliver, because there is no Torque Management available with the standalone TCUs?
- Throttle Position? Can these boxes work with our Pedals or do we need an mechanical -> electric converter at the throttle linkage?
- Shut down of the two vacuum-"switches" for the cold-start RPM raise and the E/S Switch in Europe cars.
Some things can be solved with relays, let see what we can come up with.
- Overload-switch.
