Last summer, I noticed my temperature gauge fluctuating in hot weather. Often it would get above 100 Celsius. I checked the forums here, which indicated below 90 should be average. My mechanic at Mercedes-Benz of Arlington said the three year old Genuine Mercedes fan clutch was pulling well, and the aux fans seemed fine. Everything else checked out fine. Very puzzling.
Last week in slow traffic on a 90 degree Fahrenheit day (first hot day of the year, at least that I was driving in) and with the A/C on, I took the below photo of the temp gauge. What??!! 112 degrees Celsius! I then checked out these forums and read that many had had problems with the Mercedes brand fan clutch.
I drove the car for a couple of days with NO A/C. In temps between 65 and 80 Fahrenheit, the temp stayed cool when on the highway or at least moving at a good speed but started to climb all the way up to 108 Celsius when stationary, at which point, it sounded like the aux fans would come on, and the temp would go back down to 100 Celsius or so.
I took the car back into MB of Arlington. The fan clutch, now 4 years old, worked well at first, but later was slipping badly. An intermittent problem of some sort. Further, one of the two aux fans was barely working. As the temp reached 107 Celsius, the aux fans would come on and pull the temp back down to around 100. I have ordered an ACM aftermarket fan clutch, new aux fans, and new fan shrouds. I will report back after they are installed.
