No, it's a standard W124 part. There is actually the large foam piece that goes across the inside front of the hood, and there are two harder, flexible rubber parts that go at the end of each side of the hood. There is a HOW-TO on replacement of these, I believe. I did this job some years back on my former W124 wagon, aka the "Stagwagen"Is that an .036 part?
Robert
https://www.500eboard.com/forums/showthread.php?t=2132
+1 agree. The poor thing's been passed around more than a $20 lady of the night.....With it's ownership history, shouldn't that be "The Studwagen" by now?
I vowed that over time, I would hope to reunite the car with its stock audio equipment...
I discovered that the d-bag aftermarket "installer" (who originally molested my car's sound system) also cut a mounting stud short from the trunk mounted dual amp mounting bracket. I was fortunate to liberate a pristine replacement (1248207514). Also, I couldn't recall any rear speaker foam insulation in my rear speaker deck, so I carefully removed a set (1246820310 & 1246820410) while the opportunity existed.
- Thoroughly cleaned all the areas that were going to be worked on (not Lowman-like, but he'd appreciate the effort).
oh myy goodnessGenerally speaking, the #lowmania phenomenon has run its course, similarly to #metoo. #Lowmania was always more of a behavior borne out of compulsion for extreme cleanliness. There will be residual and continuing effect for a long time to come, but #lowmania as a theme/meme very unfortunately died the day that Lowman deleted all of his YouTube videos.
..no no no...Lowmania still lives...BUT i definetly hate the fact that i deleted all the videos...it was probably the stupidest thing ive done in a long time..
I had been intending to renew my brakes at the end of the last few driving seasons....
View attachment 90259 View attachment 90260 View attachment 90261
New brakes were definitely a prerequisite towards this year's successful State motor vehicle inspection. Sometimes it takes me a while, but I always finish the job.![]()
That’s Zimmerperson, mind you....I put on Bonos and new rotors (Zimmer CoatZ) 5,000 miles ago and I'm still kind of amazed that the machining marks on the front rotors are still there. See extreme closeup picture below --- the grey right side is Zimmer's paint on the rotor hat.
Looks like Trae got to it first. (Although his may be regarding a 400E)....Speaking of boots, the HOW-TO Axel Shaft Removal would be a great addition (unless GVZ beats you to it)
...How are the rotors holding up now that you have some miles under your belt with the Bonos?
I'm sure there's more that I'll recall after I completely wake up & review my documentation,...I'll get around to posting the details as time allows.
Thanks for location address. Lol! What a journey this car has taken. If the weather is dry, I'll drive out in my 500E & take a peek.
You're doing it wrong. You gotta burn'em.Wow, you guys are peaking early! We've not even started losing leaves in earnest here in Maryland.
Lived in all three of those states for most of my life (40 years total). Don't miss any of them ... wouldn't move back to any of them!From land of Inferno (California, Washington, Oregon)
.The Pirellis rated highly in all Tire Rack performance categories except winter driving. That category has no significance to me because my 500E never sees winter or salted roads (aka my "cinco de mayo rule" in which the car goes off the road before the first snow, & doesn't come back on until May5 after April showers have washed all the road detritus away).Let us know how you like the new rubbers, Derf. There are precious few "performance" options today in the 225/55/16 size.
I've also been meaning to replace tires for the last "several" (...cough, cough) seasons. The other day I removed the OEM 16in wheels from the 500E in anticipation of reshodding with the new Pirellis. The rotors look fantastic.I like how "last few driving seasons" means you bought the pads 5 years ago and got around to it this year. I have a similar schedule.
I was able to "full circle" another lingering 500E issue. I had the epiphany of mounting the 17" monblocks onto the 500E instead of using jackstands while the OEM wheels were getting reshod. The only problem was one tire was punctured a couple seasons ago. Then I had another epiphany...the contents of the vintage tire repair box mounted to the garage wall which was from my father's business (both He & the business being long gone).It was a good day to start doing things with the 500E. I swapped out the 17" Monoblocks for the 16" 8-Holers. I was also able to locate & remove the cause of my right rear Monoblock tire's "not so slow" leak.
…an f'n screw tip. My first tire casualty from road detritus in a very, very long time. There was still just enough tread for one more driving season (with an anticipated ASR-OFF season-ending burnout into oblivion). Oh well...
