Hi All,
OK all suggestions and input here would really be appreciated. You may be familiar with my 1995 S500 C140 Coupe which I bought as a non runner (many years non running) and just got the replacement rebuilt motor installed and running. Still a project car but I want to iron out issues now towards spring when I intend to put it back on the road.
The ETA was on the car when I bought it as a claimed recent £400 rebuilt unit in the UK. Both the upper and lower engine wiring harnesses were also pro re-wired in Poland by the PO and they do appear to be well done and no issues that I can see.
The ETA is dead. I tried the re-learn procedure but nothing. When the ignition is turned on it makes one very short and abrupt motion and goes dead with no noises being emitted at all.
I did buy and fit another known good (Claim by seller) EGAS and no change. I do not have a spare w140 ETA with late style plug. I need to buy an updated spare anyway and obviously to try in the car.
It now starts up and seems to run fine albeit there is no cooling system installed so I can only run it for a few seconds. It will be fit to run normally next week when all back together.
I have just been out and hooked my star onto the Coupe tonight for the first time. After deleting the old historic codes and going into each module again after a start-up and short running spell of 10 seconds here is what I found;
LH:
008 Camshaft position sensor signal L5/1 not recognised (Weird)
017 CAN: No reception from [E-GAS] N4/1.N4/3. N4/4
EZ1 [EZL]:
017 Crankshaft position sensor L5
018 Magnets for crank shaft position sensor L5 not recognised
(Very strange since I KNOW both magnets are in their place correctly and present) Gixer?
GM / BM:
No faults stored - however
Looking in the Actual values for EZ1 CAN receptions were all ticked as OK Except CAN reception from ASR which was a fail.
EFP [E-GAS]
048: Set value potentiometer, potentiometer monitoring M16/1r1 (ETA ISSUE?) This value also stays pegged in live data whilst m16/1R2 DOES change
080 Stop Lamp Switch S9/1 (Verified with live data that the throttle switches both are working - odd)
ASR
030 CAN No reception from [E-GAS] N4/1 or fault in [E-GAS]
Avery similar set of codes is showing in this thread by @LWB250
ASR & Limp Home Mode Issues
ETA appears to have cured that car....
What do you guys think?
LH:
EZ1 [EZL]:
GM / BM:
EFP [E-GAS]
ASR
