For my 92 500E, I want to order euro headlights, the car will retain the pre-facelift look.
I have read through a couple of threads on the Euro headlights and I believe I have collected the correct part numbers to order.
I also have the contact info for Speed Autoteile, and I will send them the list of part number seen below to get quotes.
If someone has a better recommendation for a source I'd appreciate getting that information as well.
I would appreciate it if one of the boards guru's would please proof read my part number list before I send it to Speed Autoteile?
I understand from reading previous threads, that the euro pre-face 500E lights are NLA, so the list below should follow the recommendations I found in the threads for buying E500 face lift lights and swapping the lenses with pre-facelift lenses.
The trim panels are meant to be without wipers initially, and the 2nd set option is to add wipers at a later date, get them all now and paint at the same time as suggested in the posts I read.
Thanks in advance for your help..
E500 Euro Headlights
124-820-35-57 - facelift E500 Euro headlight, left
124-820-36-57 - facelift E500 Euro Headlight, right
500E Euro lenses;
000-820-12-66 - pre-facelift lenses, left
000-820-13-66 - pre-facelift lenses, right
Trim panels for these lights, blanks and the euro trim versions.
124-889-05-63 - Blank trim panel, 1986-1993, left
124-889-06-63 - Blank trim panel, 1986-1993, right
124-889-07-63 - Euro trim panel, 1986-1993, left
124-889-08-63 - Euro trim panel, 1986-1993, right
500E Euro lenses;
, appreciate you taking the time to edumacate this 500E noob...
