I’m in the process of installing my new ACM fan Clutch.
OK, I easily removed 2 Clips and 2 Bolts from
the upper shroud. There is I believe 1 more bolt on the driver’s side in towards the fan shaft.
This bolt is just spinning in place and will not break loose from the nut. At least I believe it’s a nut. Can someone confirm what size and shape of the nut? I cannot see it at present. I think I can possibly reach it from the bottom.
BUT as a Side Note, I was going to jack up the car to take a shot at it from the bottom BUT my jack FAILED. Luckily before I was under the car. It’s just to old. I’ve owned it at least 40 years. So I’m just going to go to Harbor Freight and buy a new 1-1/2 ton for $84.95 and move on.
Anyway, how about that bolt? Any info would be helpful.
