500E 3D-Modelling Project Blog
The Brabus to me an outstanding updated design that I would like to see someone like AS Designs try to copy on a real car. It appears that it is mainly the front and rear lower valances are main features with out widening the actual 124 body. Correct me if I’m wrong. My only comment is the red outlining would have to go. The rear view and exhaust setup is very attractive.
Everybody has their own preferences and I think you have provoked a lot of interest with all of your designs.
Take Care
PS: What do you have in mind for the 900E designation?
Thanks for the input @TerryA!
Yes you are correct, but also that the BRABUS is wider on the lower end at the sides whereas bodypanels and sideskirt is widen out instead of having curvature in as in original 500E and AMG one.
My plan now is to release the 900E bodykit for those who want to use it on their cars and I'm eager to see it on a real car, I know that @gsxr would do it :)
Since I've now been learning about the 3D-printing thanks to @AS Design with confirmation that it works. I've now learned what to do in the 3D-software on how to approach that. In the 3D-software, there is easy way to give it a thickness for example, with one button and adjustment on how thick you want it then the files is ready to print out. It sounds easy but it's also a lot of works. Then when 3D printing is done, one need to do custom works as well like smooth out surface, drill here and there and so on.
Just recently I have sent @AS Design the W124 Dashboard (top) and try to see if we get any luck.
Also, I want to install M159 Engine with SLS intake manifold, different suspensions and probably custom made chassi to use as a CAD model if you want to build one. Because alot of Aftermarket of muscle car they do custom made chassis.
500E new renders. Trying out of new paint and the color combinations.
Then try a M113K ;)
I would if there is a 3D-scanned available :). Otherwise it would take tons of work to model from scratch, the M119 was an exception on this case. I always wanted to install the M159 because it looks so damn good with the aluminum cover (SLS AMG) instead of plastics that we see most of the cars today. The M159 fits perfectly but just a tight space is all. If W124 can handle a V12 in then the M159 would be in right spot too!
New renders of 500E and also now available for sale of the 3D-model on a new marketplace : Mercedes-Benz W124.036 500E EuroSpec - 1992
I have also included some wireframes if you guys are interested on how I shaped the 500E from scratch!
I've been trying out the new Render Engine with different settings. Also made a modern exterior scene, where the roof is full on Solar panels. Located in the mountains.
Software Upgrade: This is going to be a lot of technical here. I got a new render engine that's called Redshift, which is a build-in engine of modelling software in Cinema 4D that will uses the GPU ( Graphic processing unit ) instead of CPU (Processor). Since I'm a student and got it on a fair price (just 10 dollars), it will be very handy. So I can actually render in real-time without delay and even achieving more realism with correct lightning and material correctness response.
When using the CPU, one image may take from 1 hour to 4 hours depends on the scene and how much it needs to be calculated depending on the light rays and where it bounces, penetrating thru transparency and so on, but with GPU renders it will take 3-10 min!
I have been preparing the file and going to start to materialize it again.
Left side is the GPU real time render, and the right side is the preview. Sorry about that checkered paint, it's for me to see that the modelling mesh is correct when applying the material so the car paint won't be distorted.
Good Job!
I do FEA for EM and that takes 7-8 hours on a high end GPU! The computer would sound just like a 500E with the AUX fans on high.
Try to use multi core processing if available.
Good Job!
That's insanely amount of data that needs to be computed! Do you use hybrid, by combining both GPU + CPU?
Our issue was with Lic which does not allow multi threading (Multi core Lic costs $40k... yes five digits!!). The processing is done by the GPU.
If you go into engineering; learning FEA will be necessary, you are already on the right track by learning highly detailed 3D modeling. You would be surprised of how many "great ideas" turned into a disaster just because the FEM was poorly detailed.
But wouldn't be better if you invest 40k dollar in GPU rather than the CPU?
I study electrical engineering, but somehow got interest in automotive just for W124.
There is a workshop in the university called CLEAR RIVER RACING for formula students
( Clear River Racing | Karlstads universitet )
where you can build mini formula and they pick several team from each field department to build one every year. Idea is to combine theory with practically so I think they also have FEM as learning curve.
Only reason I shift to GPU is because of render time of the CPU is killing me with my 10 year old CPU (Intel 3930k) and 5 year old GPU (1070TI Nvidia).
The materializing process is slowly taking shape to beautify the W124!
$40K just for the Software license to run multi core processing.
Work in progress so far. I can't believe how much time I just saved by using GPU and also memory saved for me to modelling even further more details in the future. I have been missing those AMG silver wheels so I might using it. Even now the result became much more realistic than previous work by using CPU.
the car looks basically brand new.
@Draginev,
All looks good but I have a question for you. It seems to me all new car manufacturers are turning to an exterior paint color that I call “Battle Ship Grey” including you. (No reflection on you personally) I was wondering where this phoneme came to be. Is there an automotive design magazine or something that inspires designers or is it just one designer does it and others follow.
Here in SoCal everybody is now painting homes grey also. Are Architectural Magazines showing grey also? What the hell is going on? Is this the result of governments trying to blend us all into the same person? Thinking the same way. Wearing the same clothing?
I find that color very depressing. I associate grey with war, prisons and the Mao Zedong grey uniforms of the past. :runexe:
Since your education is heading into design and you must be getting your inspiration from something I think it’s a good question for you.
Just Saying
Good point @TerryA ! I’m really glad that you asked this question in order for all of us to keep our awareness.
I agree with you about the concrete jungles we see it today surrounding us. In my hometown Örebro ( Pennybridge ) has been building new homes apartment and parking garages this last 10 years very aggressively and most of them is bland grey concrete with modern finesse as facades. Some of them would look good but others don’t. So the building becomes standard with concrete grey because it’s cheaper now and strong if mixtures were done correctly. Even cheaper than wood. That’s sadly what we most often see today, because before 1960s, the buildings type where of gothic architecture which we see in old towns in centre.
Now with this alarming concrete jungle result in higher surrounding temperature than ever and this is where (nuts environmentalist) comes in and say it’s a rise in global temperature and the blame is cars and not buildings :D ( In reality we don't even know because the data can't be trusted, meaning it can be manipulated to reach the desired goal of the lobbyist). To combat this problem, look at Singapore (How Singapore Uses Science to Stay Cool - YouTube) where they shot themselves on their foot building concrete buildings and have to dress up some greenery around the facades and on the roof to keep it cool. Some building company has come up with new wood technology to be fire resistant so it’s bringing back wood but more costly in production for those who have more capital.
So yes, we do see same buildings, same clothes, same news, less quality of foods, cars and list will go on. One will be labeled as conspiracy theorist as soon as you become critical thinker.
Now to the automotive design: There is no standard paint but most of the automotive designers choose this particular grey ( also silver ) because it’s easy and a really good contrast to have a black paint trim, wheels and grills that will look “modern” and aggressive with such same association with buildings. In reality, you can’t see much scratches on a silver/gray paint than u would on other colors. So maybe that’s why automotive industries choose it. It also act as a camouflage in concrete jungle. Grey/silver will always resemble as metal regardless.
But car 3d designer/modeler would use solid Red, silver/grey, black or white as a paint which we see on the street. They will only paint as something they took a picture with or being associated with it. But no other colors because it's very complex to choose correct color mixes.
In my defense, reason I picked black, white, grey/silver is because of the software not allowing me to have the freedom to explore colors mixes because it will never be a match 100 % of what I see on the street with CPU render, it takes many hours to see if color is correct but it will never be 100 %. But with this new GPU Render with quicker response and accuracy is higher, from 1 to 5 seconds response time, I can now freely choose any color I like without delay, and I love to try almandine red or Nautical blue on my models, it’s about time!
In this scene I modeled a modern house that is located on an island such as Ibiza or Greece, where they paint buildings to white because of less heat absorption. Maybe I need to put it whiter than looking as concrete light grey perhaps. I like to show how the car stand out, which is a good contrast with sunlight going on, inspiration comes from this
My education doesn’t go towards design, I study electrical engineering but very heavily interested in all fields of engineering and physics. What I do on 3D is on my free time that will add as a part of education later on if I would be interested in automotive engineering/design, then why not? :)
Exterior material is done, now it's just interior.
You can watch on youtube real time :)
It feels like walking into the Mercedes and customize your own W124 E500E for interiors and paint. I would like to try all of them, kinda leaning into vanilla/black leather perhaps.
Big step up game for me with GPU Render! Have a gander and tell me what you think of the paint :)
I've finished with the materializing, and worked with 3 car paints so far that I will upload more later. And I've decided to use a the underground garage environment instead with overcast weather that I think it will look good on this one.
Also the 500E will be also uploaded and rendered. The AMG one needed to have a new pictures in order for the 3D file to be up in the marketplace again to sell, at this time in lower price during this inflation.
One of the 3D professional in automotive world pointed about the headlights glass is acting weird on the front frame. It acts as a magnifying glass. Really sorry for that render, that will again be taking soon.
Headlight correction!
After the incident of headlight glass acting weird. I fixed that issue but it turns out to be more clear than necessary, so I read in the Redshift Render forum and apparently many people has same issue with glass refraction material so the issue lie in the engine itself.
Take a look between before and after and you will notice big difference.
Front view:
The rest of the photos:
Mercedes-Benz AMG 6.0 008.jpgMercedes-Benz AMG 6.0 009.jpgMercedes-Benz AMG 6.0 007.jpg
Interior shots:
@Draginev, That’s a really nice rendering. You do great work! Love ❤️ that blue and even the ducktail although I would never put one on my car.
Me personally, ducktail is the best match with the AMG bodykit. Doesn't fit on a E500E bodykit alone. That's why you will never see me putting the ducktail on a 500E....only for AMG versions. Also not for BRABUS either.
So, the good news is that since I've switched to GPU, the memory has improved on the software and PC and it allows me to fully utilize more details on the W124, to make a real CAD model. Of course when I got time.
Before doing so, is it okey to use Brembo/AMG 360mm brake disc on a 18 inch wheel for E500E? I measured between the wheel and the caliper and it's really tight, like 150mm distance. Have anyone done this? If so, any changes in knuckle?
6-piston AMG calipers with 340 or 360mm rotors can work, but may require cutting the steering stop off the knuckle, and using custom hoses with a banjo fitting. It's definitely possible, but not a "bolt on" upgrade. Photos and more info are here.
I saw it now, so I cutted of mine and could make almost 40 degrees steer.
This is amazing. Any chance you have a model of the third brake light cover you'd be willing to sell? Being able to print that would make many w124 lovers very happy.
FYI, Just saw that the third break light is available at:
From now on I'm going to use this Industrial showroom for my progress that I made in just approx 6 hours. I'm going to add some lightnings for further nice renders. Just like a real studios. This building is 50x20 m, so it's 1000 square meters. :D
I'm now giving more details to the M119 engine, with this time a new alternator. Yes, I have not installed bolts to oil pan and I may have also probably missed some other details because of saving memory was the goal. Now I don't need to :D
Hmm....someone sent me this link in Artstation regarding a Youtube video used my 3D renders.
Update: I’ve been in contact with him to refer links of my work.
Time to fix the Gauge cluster, it has been bother me for quite some time because of my ignorance...thanks to @036 for pointing it out.
This is because the setup has to be in a proper way.
So now I'm back to modelling journey again because of the free space the software and pc gave me. But this time it's going slowly because of university.
So i'm going to attempt making into this: [500Eboard] vehicle_b811430e6a497cb54a82f74b0e19a472.jpg
Excellent work! what a wonderful work! it would be much appreciated if you would develop inside of the panel of interior, as such as inside of dash board or console.
Niibe Speed
Yes, the aim for the 3D-project was to be able to 3D-print in the future by having a full CAD file. Unless Mercedes or BRABUS is going to revive the W124 again but I doubt it. The project will eventually get more details because I found solution to optimize the software and memory to go faster by not overloading my PC with lags or hindering anything. I had that issue from the start and it was infuriating. (unless I have supercomputer from NASA)
I'm selling these files I have on my profile but it's only suitable for 3D-artist automotive or gaming industry. Not ready for 3D printing yet.
This project is going to be very slow because of Uni studies so I try my best to find time to work on it. So you will see me with updates time to time. I'm glad that you enjoy my work :)
