My 1997 M119 in my R129 shakes like this in idle
I spoke to the owner of this car in the video and he said he also changed all his mounts and parts of his ignition system and it had no effect. He drove it for 23k miles with this shake and had no problems. It still shakes.
I have all new mercedes OEM engine and transmission mounts, new spark plugs, and only 70k miles on the clock. No CEL.
Perfectly smooth idle at 600rpm and no issues with performance at any RPM. Vibration does not change in P, N, D, or R. It does not increase with RPMs. Appears to be unaffected by revs while in park.
It manifests in the cabin as a rumble in the seat and door that follows the motion of the engine.
Other people's opinions who have seen the car say to just ignore it and drive it, but clearly something's not right.
Since I have a lot of time to kill chasing this as my current biggest hobby, can someone provide me a checklist of every single thing I should go through and replace in order of what's most likely to fix the problem?
I was going to do a smoke test for vacuum leaks, but I'm not sure if that will help because wouldn't a vacuum leak affect the performance and cause a rough idle RPM gauge? I do not have those symptoms, just wobbling.
