Steering wheel metallic squeak
Jlaa
Nitpickio🛡️Maximus
Now that winter has arrived, temperatures are cooler. Accordingly, my steering wheel has developed a faint squeak on occasion while turning. I think it is bc these contacts might be dry. What kind of grease should I use here? Should it be conductive?
As long as the contact is firm, I would just use some dielectric grease. I’ve messed with conductive grease before and it tends to get more places that it shouldn’t be than where it should. :)
Thank you! Would you apply the grease to the channels on the back of the steering wheel, or just dab a little on bit that protrudes from the steering column? And doesn’t dielectric grease purposely NOT conduct electricity? 🤔
no no no no... those brushes are meant to be dry. do not add any lubricant! Also, dielectric grease is an insulator, it is not conductive... this would likely cause an immediate SRS fault code and warning light. (And/or the horn not working all the time.)
The squeak is probably coming from elsewhere, but may be difficult to pinpoint. Other than Kridre's mention above, I don't recall anyone reporting noise issues related to these carbon brushes...
I used sunroof gleitpaste on the contact ring and pins. No noise since then.
Hmmmm. My noise is a faint metallic squeak that only happens when the steering wheel is turned clockwise from 150 degrees to 155 degrees. Counterclockwise is similar. Were your symptoms the same?
Hmmmmm. I dont know what else could be squeaking with such repeatable consistency….. that is metallic. 🙁
I'd start with cleaning the contacts... wire brush, fine sand paper, steel wool, or similar light abrasive. See if anything changes.
@gsxr ok I found t
Thanks. I will sand them. I found this -
And this
and this … note it talks about greasing horn contacts but NOT airbag contacts. Which contacts are for the horn vs airbag?
The 2 contacts far apart on the left side are for the horn (8:00 & 10:00 position).
The 4 contacts close together at upper right (2:00 position) are for airbag / SRS. Double double contacts for SRS redundancy.
:bbq:
Thanks everyone! I fixed the squeak. I used De-Oxit on all the spring-loaded contacts in the hub as well as the rings. Then I applied gleitpaste to the horn contacts but NOT the airbag contacts. All is quiet again!
Interesting Dave - Is the SRS current low enough that it would actually be blocked by the dielectric grease? I haven't had an experience yet where a physical connection (metal on metal) was blocked by the use of it. A tail lamp bulb for example, where dielectric grease had been applied to resist moisture ingress
Jon, I'm really not sure, but MB says to leave these contacts dry. Job 46-8240, section B. The SRS module monitors the connection to the airbag but I don't know what exactly it is looking for. I wouldn't want to find out the hard way that the airbag might not fire when needed...
