WANTED 1 lug bolt for 93 500 E
MK500
93 500E, 95 E320 Cabriolet , 95 S600 Coupe (sold)
Had one lug nut bolt stripped and have shorter one in.
Looking for a OEM replacement.
You can get 5 and have some spares...
The bolts shown above are for a W210 and are not the correct length for a 500E/R129.
500E uses a 95mm lug bolt:
Additionally, there are 3 different variations of the 95mm lug bolt. Early versions were used on some 107/126 chassis. Only the bottom one in the photo below is correct. Note the shank is larger and there is a round area at the base of the hex flats.
And what is the correct lug bolt for a set of square 18” monoblocks?
Benzy boy,
Do you have enough for a full set of monoblocks?
Yup I have a full set of very good condition original R129 lug bolts that came with the car.
I don't need them anymore because I use 55mm bolts now on my spaced Lorinsers.
As for the monoblocks I'm not sure, hoping someone can chime in.
This is what was on them before. The seller found them in the garage. So I believe I’m good for now! Great guy BTW.
You still have not stated what offset / part number the 18-inch "monoblocks" are. There are many different versions of "monoblocks". Some use different lug bolts.
