Best diagnosis for the MAF is to view live data and compare to the values in this thread. The typical failure mode for the MAF is where it's totally dead, reading a fixed number for airflow at all times (never varies). With a dead MAF, the CEL will illuminate if the car has a working CEL.engine is running rough this morning , I changed caps and tested each wire with a timing gun to see if they fire well.
When I disconnect the MAF nothing happens, idle does not change . does this mean the MAF is bad?
Point taken.Ok MAW, no codes on live data, at full temp, 2500 RPM, mash to 3000 doing generous speeds and audible burps and farts. wires caps rotors plugs fuel pumps and filter all replaced during process. A Cat-less Flieben exhaust from headers to tail. Is it the MAF?
I've never actually tried this. When I have a chance I'll see what happens on an engine running normally with a good MAF.But on my car, if I disconnect the MAF and nothing changes, the MAF is bad until proven differently.
@nocfn , in your case, without spending time/effort/money in replacing yet more parts, is it possible to verify that fuel delivery is consistent? Yes, the fuel filter and pump have been replaced but what if the pump is working sporadically (which could be capacitors in the LH). Or, what if the fuel press regulator needs replacing as @maw1124 states? It is possible as well that fuel delivery is INTERMITTENTLY inconsistent which might make things harder to diagnose.@nocfn and I are discussing his case too. On some of these "warm car stumbles" I often suspect FPR before almost everything else. But it takes someone testing the fuel pressure at the rail while the car is having troubles -- a two person diagnosis most of the time. Back when my LH was having trouble, my Jono Klink Edd China mechanic (aka Rex) focused on the FPR first, which I thought was interesting and I never forgot it. Only when the FPR was fine did he focus on the computers.
On the 124, the level sender in the tank only connects to the gauge in the cluster - no connection to the rest of the fuel system. Later chassis (particularly 211 and newer) are a different story as those have the pump inside the tank.@gsxr, while we're on this topic, how much does the fuel sender in the tank have to do with this?
For storage of less than a year, a full tank is probably a good idea, along with some StaBil fuel stabilizer. However for really long term storage (2-3 years or longer, without driving enough to burn through tank contents)... I'd seriously consider having the tank near empty. Disposing of 20+ gallons of bad gas is not fun. The 124 has a "sealed" gas tank which does pretty well keeping gas from evaporating. Newer chassis (as of 210) are different and the tank contents can evaporate over several years.I've been edumecated that I shouldn't store the cars on E because the empty tank full of air allows corrosion to set in on the fuel sender, while leaving it immersed in the cleaning agents and emollients of gasoline does not. I'm wondering if storing the car on E didn't contribute to @nocfn issues, as it seems they *might* (fingers crossed) be clearing up now that he's running a full tank of gas through again.
If you know the fuel in the tank is old or questionable, burn through it deep into reserve (or, drain and use in your lawnmower). Then refill with fresh TopTier gas along with a bottle of Red Line SI-1 cleaner and see if the issues improve. The sending unit can be opened up and cleaned if needed, while it's out you can shine a flashlight inside the tank and look for signs of corrosion. This is more of a concern in high humidity areas IMO.I've also been counseled to "just run a few tanks through and see if it clears up on its own" before putting in a new fuel sender when I had that problem.
THIS was what I needed clarified. Thanks @gsxr. I have a mix of pump inside the tank and not.On the 124, the level sender in the tank only connects to the gauge in the cluster - no connection to the rest of the fuel system. Later chassis (particularly 211 and newer) are a different story as those have the pump inside the tank.
If stuck open, vacuum will go to the carbon canister, not to the gas tank. The canister is vented to atmosphere, so this ends up causing a significant vacuum leak.4- I forgot to check the MOT valve , if stuck opened the vacuum will go to the gas tank?should this cause a CEL if stuck opened?
Disconnect the 8mm hose/tube at one side of the valve, and plug both ends, to seal off / separate the engine.Can I pinch the hose to simulate closed ?
Not likely to get a CEL. The CEL only illuminates for emissions-related faults. It doesn't care about anything else. But, the ETA (or E-GAS) is a potential cause since those 2 components control idle RPM. Odd there would be no fault codes though. How old is the ETA? Ever rebuilt?5- from what I read if this was ETA related I would got a CEL??
Most likely vacuum leak, or an issue with ETA or E-GAS. Also make sure the NSS signals are correct, view live data while moving the gearshift through each position.Idle high in park
Is this at part throttle, full throttle, or both? Will it pull cleanly to redline or not? A 'miss' implies ignition misfire, do you mean a hesitation in power delivery? They are not the same thing.Good power but a miss before full power comes on
How old are the engine mounts?I feel a miss especially in drive and stopped slight engine shake
At 30yrs, with a hunting and surging idle, given how hot these engines run and how tight is the engine bay, THIS seems the best advice. Otherwise I fear you'll be hunting vacuum leaks literally forever. If some of the tubes are brittle, it's pretty safe to assume they're all brittle.Honestly, I would strongly consider just replacing all of the soft bits at the intake manifold and the top end of the engine. That would include all vacuum lines, gaskets, rubber nipples and connectors, black rubber air hoses atop the manifold, Tecalan tube that goes off the ETA, ETA gasket, EGR gasket, ETA rubber boot, rubber smog pump hoses, possibly the rubber donuts that mate the halves of the intake together.....the whole works. You won't regret it and it's a job that could be done in a day, or over a weekend.
EZL live data will positively confirm if there is a misfire or not, AND will show you the specific cylinders misfiring.upper and lower harness is new of 2 years , cams are connected , it shows a curent code but not stored code . will see the live data on the EZL.
This tells you that a spark was sent through that wire, but you cannot tell if the plug is firing. If the spark is shorting out somewhere else you'd still see a pulse but there would be a misfire in the cylinder. I have never used my timing light on an M119...my timing light days are foggy .If I get a timing light pulse on each wire does that meet the distributor is sending electricity or the spark plug igniting ?
Can I get a pulse even if the plug does not fire ?
As Gerry said, they almost never fail. And, you'd never see both fail simultaneously. They often leak oil though, which should be remedied as it can cause misfires from oil soaking the lower edge of the distributor cap.do cam solenoids go bad?
Since your ETA is original... probably time to rebuild/replace it. What fault codes are on the E-GAS module after you get limp mode?every time I got the ASR light in the morning its in limp node until I restart.
Most codes remain in memory permanently until you clear them. This is why you can get "code diarrhea" if they have not been checked/cleared in a very long time, like 10+ years...how long do the codes stay in memory ? I will scan tomorrow
That is an internal switch inside the ETA. Time to send it to Victor for a rebuild, or gamble on a used one...1-As for the asr light and limp sometimes in the morning got code in EFP module 051 idle speed safety contact m16/1s2??
Seems like there is a wiring issue between the LH module and the cam solenoids. You'll need to trace the wires between those two points and figure out what's going on. Use the docs linked below.2- I still get the cam codes with 3 different LH modules .also if I try to activate cam 1 or 2 it says fuction aborted .
if I put a 12v battery to the magnet I hear it click , I also tried a spare I have , the code is stored current faults what are your thoughts?
