900hp Twin turbo M119 - drool warning!
500AMM
500E explorer
I was surfing through the Norwegian 500E/E500 group on FB today, and came across this twin turbo M119 powered W201 prepared for hill climbing. I have no information about the power output. Watch some of the videos, talk about thunder! :wow:
W201 M119 twin turbo (1).jpg W201 M119 twin turbo (2).jpg W201 M119 twin turbo (3).jpg
Ble ikke noe film denne dynokjøringen. Men etter litt trykking så er den fin igjen. Fikk litt mere effekt, selv på samme trykk. Fantastisk😁
730hk/840nm på hjul 0.85 bar trykk
Tusen hjertelig takk for innsatsen til sigve Bergum, Bergum Tekniske
Neste er å se om man får testet den litt på asfalt, er spent som fy
This dyno run was not a movie. But after a little pressing, it's fine again. Got a bit more effect, even at the same pressure. Fantastic 😁
730hp/840nm on wheels 0.85 bar pressure
Many heartfelt thanks for the efforts of sigve Bergum, Bergum Tekniske
Next is to see if you can test it a bit on asphalt, I'm excited as hell
It has a dry sump oil system! Wow. Appears they tried a custom wet-sump pan back in May 2020 but switched to dry sump in April 2021.
And, radiator (cooling system) in the trunk.
