Nope. Not sure at all. It would probably be good to figure that out too.Are you sure clutches for the ASD are still available? Even if you locate an ASD differential, the likelihood that the clutches are toast is fairly high, I believe.
It's not an assigned number. This is not what you'd call "organized." I put 127 on because if you find the letter of the alphabet whose ordinal matches each digit you get "ABG," the abbreviated form of the Gambler slogan "always be gambling."Looks like fun!!
Pity they could have assigned you 129 as your number...
I happened to just see this comment and thought it might be of some interest to you:Made it home from the first Gambler 500 trip of the year. The car did remarkably well. I had a rear lower shock bushing disintegrate on day one, so there was a clunk throughout the whole trip. All the gear in the rear of the car made the rear sit down lower than I wanted, so I'll have to look at options to support the weight better.
I'm thinking of possibly converting to aftermarket air shocks in the rear. Should be fairly straightforward. Then I can just air up the shocks as needed to support the weight when I'm loaded down heavily.
The air conditioning was mediocre. That's a funny thing to complain about in the world of Gamblers. The vast majority of cars have no air conditioning at all. This car probably has leaks in the vacuum control system which are causing the center dash vents and floor vents to not work. I'd like to sort that out before the next run if I can.
I really want to do something with the rear diff. It desperately needs lower gears. I have to manually shift to 1st every time I stop if I want to get off the line reasonably. I'd also really like an LSD of some sort. I was thinking ASD might be an interesting way to go. I'm not sure what exactly is involved though.
Ideally, I'd source an ASD diff with a low gear ratio (if such a thing exists) and then rig up some kind of system to control the locking functionality. I don't know what donor cars to look for, or if they were even available with 3.4x-up gears. Obviously I need to stay with a 210mm ring gear if there's any hope of the diff surviving.
I'm just starting to research the ASD thing. If anyone has any good info on donors, let me know.
Nice work on the vents, air shocks, and harness!I've been back from the Oregon Gambler for about a week and have begun addressing the biggest issues with the car. The two biggest problems were the center AC vents not working and the rear suspension sitting too low when the trunk is fully loaded.
Old oil pressure sensors can read lower than normal. My guess is that's what you are seeing. Factory spec claims 0.5 bar is acceptable at hot idle, reality should be more like 1.0-1.2 bar minimum at hot idle. This will vary with the oil viscosity and temp of course.I also replaced the oil pressure sensor with one off another engine I have. It's used, so I don't expect perfection.
Oil pressure reads 3 bar cold, and 3 bar hot over maybe 1500-2000 RPMs, below 1500 it drops pretty low. Hot idle is under 1 bar. My ears tell me there's nothing to be concerned about. The car never makes any valve noise, so I'm confident oil pressure is fine. Is <1 bar normal at hot idle? My 400E shows around 2 bar at hot idle.
Yep, same here, every 124 that I've owned needs the low-pressure p/s hoses replaced.I also replaced the beloved 15mm power steering reservoir hose. I'm glad I just bought a couple meters of that hose a while back. Every M119 car I've touched needed that hose replaced.
I think there may be aftermarket clutch plates available, but it's still a lot of work to replace those if available at a decent price. I did this job nearly two decades ago (!) when building my first LSD.I'm still on the lookout for a diff with shorter gears. I've found a couple and am just trying to negotiate the best price. I had thought about an ASD diff, but clutch plates are not readily available. I'm sure I could have originals relined or have custom clutches made, but the cost of procuring an ASD diff, plus the cost of new custom clutches makes the whole thing pretty pricey. Probably not worth it.
This - in bold - above: ^^^I'm also considering a FGS valve body. I can get one for around $100 from the pick and pull. I'm seriously considering it. I don't know that it's really worth $100 to add FGS to this beater car, but the way I'm kind of thinking about it is that this car is just a shed full of spare parts that I can drive. If some day I decide I'm done with it, all the good parts can come back out and anything I don't need can get sold. That FGS valve body should be able to easily be sold for more than the $100 it will cost me.
I believe the tailshaft housing is different between the 124/140 version and the 129, along with a different rear/trans mount. The internals should all be identical.That reminds me. Does anyone know what differences there are between the 722.3 found in the W140 500SEL and the 500SL? I know they're not the same exact model, but I'm curious what differences there might be and whether there would be any advantage to running the 500SEL trans instead of the 500SL trans.
Take the side plates off the VB before installing, inspect for broken springs. You can replace the K1/K2 springs/pistons with new if desired, parts are relatively inexpensive.
I haven't checked the clutch. I'll give that a look.Is the viscous fan fully engaged and roaring up to 3500rpm? With AC on max, coolant temp should be ~105C max even in 100F ambients. If the fan is roaring you should have airflow, next up is making sure the radiator/condenser fins are not blocked, and making sure the thermostat isn't defective or somehow modified.
Yeah, that's us. You can see the Offroadster in that first picture.Just stumbled across this by chance:
Yup. I actually have one 95 with the later style and then a bunch of the earlier ones. Fairly sure this car has the earlier 116 style. The 94 S500 I had that had the broken engine block had all new cooling system parts. Pretty sure the thermostat and water pump were brand new. I'll see if I can find those. I may just swap the assembly in and be done with it.Remember there are different types of thermostats which are not interchangeable. The switch occurred during 1995 USA model year, and I think all your M119's are 1994 or older, so they should all be interchangeable (116- part number, more info here).
Ah, I see that now. You're right. That would be a pain. Ok, maybe I'll just swap in the thermostat.Also - the 1993 car will have the "solid" harmonic balancer, which must come off to access one single stupid bolt at the bottom of the pump. Removing the balancer is a chore in itself. The late (mid-95 and newer) balancers have a spoked design and you can R&R the water pump without removing the balancer. I've always wondered if we could "upgrade" older engines to the late balancer design without messing up, uh, balance.
You're right. I see that with the later style thermostat I have here. I wonder why those cars (apparently) didn't have issues. Doesn't matter. I ordered a new one.The M119 (and most Mercedes) cooling system design cannot cool properly without the thermostat installed. It's not a simple 1-way valve as in many old domestic V8 engines. It's a 2-way valve that bypasses the radiator when cold, then starts to mix in some cool water from the radiator when partly open. When fully open, the t-stat blocks off the return path of hot coolant from the block so the water pump only ingests cool water from the radiator. With the t-stat removed, there's no way to prevent hot water from recirculating.
More details here:
https://www.500eboard.co/forums/misc/Manuals/Servicev3.2/W124/w124CD1/Program/Engine/104/20-0050.pdf
TLDR:
This is not quite correct, although I sometimes wish it was, because it sure would be easier to troubleshoot. The [low speed] fans turn on based on refrigerant pressure [for the 124 - see post below with more info]. It appears the R129 uses a different switch than most 124, and triggers the low speed fan at 20 bar (290 psi!), then shuts it off below 16 bar (230psi). [Edit: The pressure switch may trigger high speed fans on the 129.]To the best of my knowledge, the fans should be on any time the AC conpressor is on.
Interesting. I thought the pressure switch engaged the high speed circuit.This is not quite correct, although I sometimes wish it was, because it sure would be easier to troubleshoot. The fans turn on based on refrigerant pressure. It appears the R129 uses a different switch than most 124, and triggers the low speed fan at 20 bar (290 psi!), then shuts it off below 16 bar (230psi).
Good call. I might even consider doing that proactively. It would be nice to charge the system by weight to ensure the charge is correct. Performance seems decent, so I suspect it's probably fine, but it wouldn't hurt to evacuate it and find out for sure.Those numbers are way high, the early 124 (1986-89?) had a similar switch that was replaced with one that turns the fans on/off at 16/12 bar, respectively. The lower-pressure switch runs the fan more often. If you ever evacuate the system you could replace the Green switch with the Red.
The high speed fans trigger based on engine temp, normally on at 107°C and off in the high 90's.Interesting. I thought the pressure switch engaged the high speed circuit.
Ok that makes sense. The wiring diagram I was looking at in WIS only had the pressure switch on the high speed side of the circuit. Different from the W124.HOWEVER: Per the chart below, it appears the 129 has different triggers for low vs high speed fans. If that data is correct, it seems the low fan on the R129 is supposed to turn on at 100°C engine temp, and the high fan triggers at 107°C *or* at refrigerant pressure above 20 bar.
My dash temp reads a few degrees high, I don’t think it matters in terms of it’s not an engine management sensor input.Cooling system fixed. Ambient temperature... not so much. Actual temp is 105 F. Also, the gauge cluster lens is filthy. Guess that's what I get for offroading a convertible.
I appreciate it, but the 93 is a totally different animal from the 98. The WIS diagnostics are pretty simple. It does actually provide precise step by step tests using a multimeter that are pretty conclusive. The only real question is whether the 4-6 volt nominal value is correct, or if the documentation is inaccurate.I can hook my 98 up to STAR and upload screen shots of the HHT-Win actual values if this would help?
Best practice is generally to test a suspected bad module by installing it in an otherwise known good car. Because it's possible that another issue within the problematic car may have been the cause of the damage to the suspected bad module, installing a known-good module just for testing can potentially cause the good module to fail. To avoid this, the better option is to put the suspected bad module in the good car.Obvious possible next steps are:
Borrow / try a known good roof module
Hook it up to a STAR or other decent diagnostic scanner and see if anything shows up
If you suspect that, you really need to know before continuing to use roof modules as fusesI appreciate it, but the 93 is a totally different animal from the 98. The WIS diagnostics are pretty simple. It does actually provide precise step by step tests using a multimeter that are pretty conclusive. The only real question is whether the 4-6 volt nominal value is correct, or if the documentation is inaccurate.
I suspect it's accurate, and that I have two modules that have both failed in similar fashion. These modules are known to be fragile, and it would seem likely that multiple modules could suffer the exact same failure.
Sounds like the "B" switch is not working, but the kickdown switch below the pedal is working correctly.The other issue is with the transmission. I'd installed a FGS valve body from a 400E, and that gas been working fine. The weird thing is that shifting to the B range doesn't always seem to work. Many times the car will shift to 2nd even with the shifter in B. Also, when I'm slowing down and want to drop to first in preparation for a corner exit, it'll stay in 2nd until I hammer the throttle. Once I mat it, the car will downshift, but it won't do it just by shifting to B. My 400E always responds when I shift to B. The SL usually doesn't. Any ideas what I should look at?
Yeah, that's what I figured. It's weird though, because sometimes it does work. Also, if I put it in B, and then tap the throttle to the floor, activating the kick down, then it will downshift to 1st and stay there. I wouldn't think it would do that if the B switch was bad.Sounds like the "B" switch is not working, but the kickdown switch below the pedal is working correctly.
